Need some help!!! Understanding P codes and DTC codes
Hey everyone need a lil help here. Im located in USA/ Ohio. The car is a 2004 audi a8l 4.2 v8 and has about 176,000 miles,give or take 1000. After the car gets warmed up it starts to smoke a little from the back right of the engine/drivers side.This is the first scan i did. Really wanna know what should i do. OBDeleven data log Date: 2023-04-17 18:27 VIN: WAUML44E84N023795 Car: Audi A8 L Year: 2004 Body type: Long Mileage: 285420 KM ---------------------------------------------------------------00 Steering Angle Sensor Trouble codes: No trouble codes found ---------------------------------------------------------------01 Engine System description: 4.2L V8/5V A Software number: 4E0910560A Software version: 0070 Hardware number: 4E0907560 Serial number: AUX3Z0D2537890 Coding: 0007773 Trouble codes: P1629 - Databus drivetrain Missing message from ADR control module Upper limit exceeded static P1573 - Left Electro-Hydraulic Engine Mount Solen.val. Open circuit Nosignal/communication static P1340 - Camshaft pos./crank shaft pos. sensor Incorrect allocation Upper limit exceeded static P1602 - Power supply terminal 30 Voltage too low Lower limit not reached Intermittent P0341 - Camshaft Pos.Sensor Circ. Range/Performance No signal/communication Intermittent ---------------------------------------------------------------02 Transmission System description: AG6 09E 4,2L5V USA Software number: 4E0910156E Software version: 0110 Hardware number: 09E927156A Serial number: 0027809 Coding: 0000002 Trouble codes: P1881 - Target acceleration signal missing message static P0560 - System Voltage Malfunction Intermittent ---------------------------------------------------------------02 Transmission System description: AG6 09E 4,2L5V USA Software number: 4E0910156E Software version: 0110 Hardware number: 09E927156A Serial number: 0027809 Coding: 0000002 Trouble codes: P1881 - Target acceleration signal missing message static P0560 - System Voltage Malfunction Intermittent ---------------------------------------------------------------03 Brakes System description: ESP 5.7 allrad H44 Software number: 4E0910517B Software version: 0500 Hardware number: 4E0614517M Coding: 0007597 Trouble codes: 01826 - Steering angle sensor, voltage supply terminal 30 Intermittent 02083 - Message for delay request No signal/communication static---------------------------------------------------------------05 Keyless System System description: FBS AUDID3 H03 Software number: 4E0910131 Software version: 0140 Hardware number: 4E0909131A Serial number: AUX3Z0D2537890 Coding: 0263168 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: No trouble codes found ---------------------------------------------------------------06 Passenger Seat System description: Sitzmemory BFS H07 Software number: 4E0910760C Software version: 0060 Hardware number: 4E0959760 Serial number: 5DS 008 795-03 Coding: 3940448 Trouble codes: 01727 - Backrest adjust. switch, backward, frt. pass. seat mechanical malfunction static 01726 - Backrest adjust. switch,forward, frt. pass. seat mechanical malfunction static 01733 - Head restraint adjust. switch, down, frt. pass. seat mechanical malfunction static 01732 - Head restraint adjustment switch, up, frt. pass. seat mechanical malfunction static ---------------------------------------------------------------07 Display System description: Interfacebox H43 Software number: 4E0910729J Software version: 0600 Hardware number: 4E0035729 Serial number: 346CI047511084 Coding: 0000000 Subsystems: System description: E0380 BedienteilH01 Software number: 4E0910611 Software version: 0050 Trouble codes: 02084 - Component protection no or incorrect basic setting/adaptation static 01042 - Control module not coded---------------------------------------------------------------08 Air Conditioning System description: KLIMAAUTOMAT 016 Software number: 4E0910043A Software version: 0300 Hardware number: 4E0820043B Serial number: 00000000041024 Coding: 1151313 Subsystems: System description: Sitzluefter FS H02 Software number: 4E0910772A Software version: 010 System description: Sitzluefter BFS H02 Software number: 4E0910772A Software version: 010 Trouble codes: 00066 - Right rear footwell heater Electrical error in circuit static 00065 - Left rear footwell heater No signal/communication static 00819 - High pressure sensor Lower limit not reached Intermittent---------------------------------------------------------------09 Central Electrics System description: ILM Fahrer H12 Software number: 4E0910279J Software version: 0190 Hardware number: 4E0907279J Coding: 0123113 Subsystems: System description: Wischer WWS D3 H50 Software number: 4E1910113B Software version: 0400 Coding: 0000035 System description: REGENLICHTSENSORH10 Software number: 4E0910557 Software version: 0030 Coding: 0139548 Trouble codes: 00908 - Wiper motor control module No signal/communication Intermittent ---------------------------------------------------------------0E Media Player System description: CD-Changer H43 Software number: 4E0910111C Software version: 0340Hardware number: 4E0035111 Serial number: AUZ5ZBD1035996 Trouble codes: No trouble codes found ---------------------------------------------------------------13 Adaptive Cruise Control System description: ABSTANDSREGELUNGH02 Software number: 4E0910561E Software version: 0040 Hardware number: 4E0907561E Coding: 0011218 Trouble codes: No trouble codes found ---------------------------------------------------------------15 Airbag System description: Airbag 8.4E+ H10 Software number: 4E0910655A Software version: 0920 Hardware number: 4E0959655E Coding: 0530707 Trouble codes: No trouble codes found---------------------------------------------------------------16 Steering Column System description: Lenksäulenmodul H13 Software number: 4E0910549 Software version: 0040 Hardware number: 4E0953549A Coding: 0012251 Subsystems: System description: Lenkradmodul H04 Software number: XXXXXXXXXXX Software version: 0080 Trouble codes: No trouble codes found ---------------------------------------------------------------17 Dashboard System description: KOMBIINSTR. VDO H51 Software number: 4E0910930 Software version: 0090 Hardware number: 4E0920980C Serial number: AUDID3D2000686 Coding: 0016233Trouble codes: 01319 - Control module for distance control Implausible signal static ---------------------------------------------------------------19 Gateway System description: Gateway H07 Software number: 4E0910468A Software version: 0040 Hardware number: 4E0907468D Serial number: 02006036050090 Long coding: FEFE7FDD1B2304 Trouble codes: 02001 - Data-Bus distance regulation Faulty static ---------------------------------------------------------------25 Immobilizer System description: FBS AUDID3 H03 Software number: 4E0910131 Software version: 0140 Hardware number: 4E0909131A Serial number: AUX3Z0D2537890 Coding: 0263168 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: No trouble codes found ---------------------------------------------------------------28 Rear Climate Control System description: KLIMA-STG. FOND 015 Software number: 4E0910158 Software version: 0210 Hardware number: 4E0919158A Serial number: 00000000016939 Coding: 0000000 Trouble codes: No trouble codes found ---------------------------------------------------------------34 Chassis Control System description: LUFTFDR.-CDC H05 Software number: 4E0910553E Software version: 4290 Hardware number: 4E0907553E Coding: 0015510 Trouble codes: 00778 - Steering angle sensor Implausible signal Intermittent 00142 - Left front dampening adjustment valve Electrical error in circuit Intermittent ---------------------------------------------------------------36 Driver Seat System description: Sitzmemory FS H07 Software number: 4E0910760C Software version: 0060 Hardware number: 4E0959760 Serial number: 5DS 008 795-03 Coding: 4071522 Trouble codes: No trouble codes found ---------------------------------------------------------------37 Navigation System description: MNS US H43 Software number: 4E0910887K Software version: 0570 Hardware number: 4E0919887C Serial number: 355CM047517640 Trouble codes: 00003 - Control module Faulty static---------------------------------------------------------------38 Roof Electronic System description: Dachknoten D3 H01 Software number: 4E0910135A Software version: 0090 Hardware number: 4E0907135 Serial number: 00000405000051 Coding: 0003477 Trouble codes: No trouble codes found ---------------------------------------------------------------42 Driver Door System description: Türsteuer.FS BRM007 Software number: 4E1910802 Software version: 0110 Hardware number: 4E1959801 Coding: 0028196 Trouble codes: 00913 - Front right window lift switch, driver side Implausible signal Intermittent ---------------------------------------------------------------46 Comfort System System description: Komfortgeraet H04 Software number: 4E0910289A Software version: 0040Hardware number: 4E0907289 Serial number: W040403300064 Coding: 0065086 Subsystems: System description: Heckdeckel H06 Software number: 4E0910853 Software version: 0060 System description: Neigungssensor H03 Software number: 4E0907719 Software version: 0020 Trouble codes: 01134 - Alarm horn Electrical error in circuit static 01134 - Alarm horn No signal/communication static 01134 - Alarm horn Faulty static 01504 - License plate lamp Open circuit/short circuit to ground static ---------------------------------------------------------------47 Sound System System description: DSP-High D3/AUX H13 Software number: 4E0910223HSoftware version: 0370 Hardware number: 4E0035223B Serial number: 00000000000515 Coding: 0000016 Trouble codes: No trouble codes found ---------------------------------------------------------------4F Central Electrics 2 System description: ILM Beifahrer H09 Software number: 4E0910280A Software version: 0040 Hardware number: 4E0907280A Serial number: 00000000036397 Coding: 0010111 Subsystems: System description: UGDO HL US H02 Software number: 4E0910511A Software version: 0030 Trouble codes: 02269 - Final shut-off display unit extraction-no return message No signal/communication Intermittent ---------------------------------------------------------------52 Passenger DoorSystem description: Türsteuer.BF BRM007 Software number: 4E1910802 Software version: 0110 Hardware number: 4E1959802 Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------53 Parking Brake System description: EPB AV1C1010 H01 Software number: 4E0910801A Software version: 1010 Hardware number: 4E0907801 Coding: 0000532 Trouble codes: 02433 - Right parking brake motor voltage supply Open circuit static 02596 - Rear brake linings worn Lower limit not reached static 02596 - Rear brake linings worn Implausible signal static ---------------------------------------------------------------55 Headlight Regulation System description: Pre-AFS H01Software number: 4E0910357 Software version: 0040 Hardware number: 4E0907357 Coding: 0000001 Trouble codes: No trouble codes found ---------------------------------------------------------------56 Radio System description: TUNER EU/US/RDW H41 Software number: 4E0910541C Software version: 0290 Hardware number: 4E0035541B Serial number: 304CQ047585429 Coding: 0000002 Trouble codes: No trouble codes found ---------------------------------------------------------------61 Battery Regulation System description: ENERGIEMANAGER H02 Software number: 4E0910181B Software version: 0240 Hardware number: 4E0915181 Hardware version: 000 Serial number: 00000001703956Subsystems: System description: von VA0 350320K1H2 Software number: 000915105AK Long coding: 303030393135313035414B5641303335303332304B314832 Trouble codes: No trouble codes found ---------------------------------------------------------------62 Rear Left Door System description: Türsteuer.HL BRM007 Software number: 4E0910802 Software version: 0110 Hardware number: 4E0959801A Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------65 Tire Pressure System description: Reifendruck 2 H01 Software number: 4E0910273 Software version: 0210 Hardware number: 4E0907273 Coding: 0212127 Trouble codes: 01521 - Tire pressure sensor Lower limitnot reached static ---------------------------------------------------------------72 Rear Right Door System description: Türsteuer.HR BRM007 Software number: 4E0910802 Software version: 0110 Hardware number: 4E0959802A Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------75 Telematics System description: Telematik USA1 Software number: 4E0910616 Software version: 0080 Hardware number: 4E0035616B Serial number: 0000ATD3009377 Coding: 0000005 Trouble codes: 01531 - Emerg.battery Lower limit not reached static 01336 - Combination Comfort databus Faulty Intermittent---------------------------------------------------------------76 Parking Assistance System description: Parkhilfe 8-Kan H12 Software number: 4E0910283A Software version: 0020 Hardware number: 4E0919283B Serial number: 08730407102439 Coding: 0001208 Trouble codes: 01547 - Center right rear park assist sensors Open circuit/short circuit to ground static
Ant Pacc (04-19-2023)
Second scan after clearing them
This is the scan i did after i cleared the codes. My dash now reads ACC unavailable not sure what that means. I do know that i cant change the fan speed or temp on driver side/ passenger side controls work fine. Battery seems to die but thats due to the gears in the radio are broke so i gotta push it down to completely close.Where should i start to get this car back running properly. OBDeleven data log Date: 2023-04-17 18:29 VIN: WAUML44E84N023795 Car: Audi A8 L Year: 2004 Body type: Long Mileage: 285420 KM ---------------------------------------------------------------00 Steering Angle Sensor Trouble codes: No trouble codes found ---------------------------------------------------------------01 Engine System description: 4.2L V8/5V A Software number: 4E0910560A Software version: 0070 Hardware number: 4E0907560 Serial number: AUX3Z0D2537890 Coding: 0007773 Trouble codes: P1629 - Databus drivetrain Missing message from ADR control module Implausible signal static-----------------------------------------------------------02 Transmission System description: AG6 09E 4,2L5V USA Software number: 4E0910156E Software version: 0110 Hardware number: 09E927156A Serial number: 0027809 Coding: 0000002 Trouble codes: No trouble codes found ---------------------------------------------------------------03 Brakes System description: ESP 5.7 allrad H44 Software number: 4E0910517B Software version: 0500 Hardware number: 4E0614517M Coding: 0007597 Trouble codes: 02083 - Message for delay request No signal/communication static ---------------------------------------------------------------05 Keyless System System description: FBS AUDID3 H03 Software number: 4E0910131 Software version: 0140 Hardware number: 4E0909131A Serial number: AUX3Z0D2537890 Coding: 0263168 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: No trouble codes found ---------------------------------------------------------------06 Passenger Seat System description: Sitzmemory BFS H07 Software number: 4E0910760C Software version: 0060 Hardware number: 4E0959760 Serial number: 5DS 008 795-03 Coding: 3940448 Trouble codes: 01727 - Backrest adjust. switch, backward, frt. pass. seat mechanical malfunction static01726 - Backrest adjust. switch, forward, frt. pass. seat mechanical malfunction static 01733 - Head restraint adjust. switch, down, frt. pass. seat mechanical malfunction static 01732 - Head restraint adjustment switch, up, frt. pass. seat mechanical malfunction static ---------------------------------------------------------------07 Display System description: Interfacebox H43 Software number: 4E0910729J Software version: 0600 Hardware number: 4E0035729 Serial number: 346CI047511084 Coding: 0000000 Subsystems: System description: E0380 BedienteilH01 Software number: 4E0910611 Software version: 0050 Trouble codes: 02084 - Component protection no or incorrect basic setting/adaptation static---------------------------------------------------------------08 Air Conditioning System description: KLIMAAUTOMAT 016 Software number: 4E0910043A Software version: 0300 Hardware number: 4E0820043B Serial number: 00000000041024 Coding: 1151313 Subsystems: System description: Sitzluefter FS H02 Software number: 4E0910772A Software version: 010 System description: Sitzluefter BFS H02 Software number: 4E0910772A Software version: 010 Trouble codes: No trouble codes found ---------------------------------------------------------------09 Central Electrics System description: ILM Fahrer H12 Software number: 4E0910279J Software version: 0190 Hardware number: 4E0907279J Coding: 0123113 Subsystems:System description: Wischer WWS D3 H50 Software number: 4E1910113B Software version: 0400 Coding: 0000035 System description: REGENLICHTSENSORH10 Software number: 4E0910557 Software version: 0030 Coding: 0139548 Trouble codes: No trouble codes found ---------------------------------------------------------------0E Media Player System description: CD-Changer H43 Software number: 4E0910111C Software version: 0340 Hardware number: 4E0035111 Serial number: AUZ5ZBD1035996 Trouble codes: No trouble codes found ---------------------------------------------------------------13 Adaptive Cruise Control System description: ABSTANDSREGELUNGH02 Software number: 4E0910561E Software version: 0040Hardware number: 4E0907561E Coding: 0011218 Trouble codes: No trouble codes found ---------------------------------------------------------------15 Airbag System description: Airbag 8.4E+ H10 Software number: 4E0910655A Software version: 0920 Hardware number: 4E0959655E Coding: 0530707 Trouble codes: No trouble codes found ---------------------------------------------------------------16 Steering Column System description: Lenksäulenmodul H13 Software number: 4E0910549 Software version: 0040 Hardware number: 4E0953549A Coding: 0012251 Subsystems: System description: Lenkradmodul H04 Software number: XXXXXXXXXXX Software version: 0080Trouble codes: No trouble codes found ---------------------------------------------------------------17 Dashboard System description: KOMBIINSTR. VDO H51 Software number: 4E0910930 Software version: 0090 Hardware number: 4E0920980C Serial number: AUDID3D2000686 Coding: 0016233 Trouble codes: 01319 - Control module for distance control Implausible signal static ---------------------------------------------------------------19 Gateway System description: Gateway H07 Software number: 4E0910468A Software version: 0040 Hardware number: 4E0907468D Serial number: 02006036050090 Long coding: FEFE7FDD1B2304 Trouble codes: No trouble codes found---------------------------------------------------------------25 Immobilizer System description: FBS AUDID3 H03 Software number: 4E0910131 Software version: 0140 Hardware number: 4E0909131A Serial number: AUX3Z0D2537890 Coding: 0263168 Subsystems: System description: ELV Software number: XXXXXXXXXXX Software version: XXXX Trouble codes: No trouble codes found ---------------------------------------------------------------28 Rear Climate Control System description: KLIMA-STG. FOND 015 Software number: 4E0910158 Software version: 0210 Hardware number: 4E0919158A Serial number: 00000000016939 Coding: 0000000 Trouble codes: No trouble codes found---------------------------------------------------------------34 Chassis Control System description: LUFTFDR.-CDC H05 Software number: 4E0910553E Software version: 4290 Hardware number: 4E0907553E Coding: 0015510 Trouble codes: No trouble codes found ---------------------------------------------------------------36 Driver Seat System description: Sitzmemory FS H07 Software number: 4E0910760C Software version: 0060 Hardware number: 4E0959760 Serial number: 5DS 008 795-03 Coding: 4071522 Trouble codes: No trouble codes found ---------------------------------------------------------------37 Navigation System description: MNS US H43 Software number: 4E0910887K Software version: 0570 Hardware number: 4E0919887C Serial number: 355CM047517640Trouble codes: No trouble codes found ---------------------------------------------------------------38 Roof Electronic System description: Dachknoten D3 H01 Software number: 4E0910135A Software version: 0090 Hardware number: 4E0907135 Serial number: 00000405000051 Coding: 0003477 Trouble codes: No trouble codes found ---------------------------------------------------------------42 Driver Door System description: Türsteuer.FS BRM007 Software number: 4E1910802 Software version: 0110 Hardware number: 4E1959801 Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------46 Comfort System System description: Komfortgeraet H04 Software number: 4E0910289A Software version: 0040 Hardware number: 4E0907289 Serial number: W040403300064 Coding: 0065086 Subsystems: System description: Heckdeckel H06 Software number: 4E0910853 Software version: 0060 System description: Neigungssensor H03 Software number: 4E0907719 Software version: 0020 Trouble codes: 01134 - Alarm horn Electrical error in circuit static 01134 - Alarm horn No signal/communication static 01134 - Alarm horn Faulty static 01504 - License plate lamp Open circuit/short circuit to ground static ---------------------------------------------------------------47 Sound System System description: DSP-High D3/AUX H13 Software number: 4E0910223HSoftware version: 0370 Hardware number: 4E0035223B Serial number: 00000000000515 Coding: 0000016 Trouble codes: No trouble codes found ---------------------------------------------------------------4F Central Electrics 2 System description: ILM Beifahrer H09 Software number: 4E0910280A Software version: 0040 Hardware number: 4E0907280A Serial number: 00000000036397 Coding: 0010111 Subsystems: System description: UGDO HL US H02 Software number: 4E0910511A Software version: 0030 Trouble codes: No trouble codes found ---------------------------------------------------------------52 Passenger Door System description: Türsteuer.BF BRM007 Software number: 4E1910802 Software version: 0110 Hardware number: 4E1959802Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------53 Parking Brake System description: EPB AV1C1010 H01 Software number: 4E0910801A Software version: 1010 Hardware number: 4E0907801 Coding: 0000532 Trouble codes: 02433 - Right parking brake motor voltage supply Open circuit static 02596 - Rear brake linings worn Lower limit not reached static 02596 - Rear brake linings worn Implausible signal static ---------------------------------------------------------------55 Headlight Regulation System description: Pre-AFS H01 Software number: 4E0910357 Software version: 0040 Hardware number: 4E0907357 Coding: 0000001Trouble codes: No trouble codes found ---------------------------------------------------------------56 Radio System description: TUNER EU/US/RDW H41 Software number: 4E0910541C Software version: 0290 Hardware number: 4E0035541B Serial number: 304CQ047585429 Coding: 0000002 Trouble codes: No trouble codes found ---------------------------------------------------------------61 Battery Regulation System description: ENERGIEMANAGER H02 Software number: 4E0910181B Software version: 0240 Hardware number: 4E0915181 Hardware version: 000 Serial number: 00000001703956 Subsystems: System description: von VA0 350320K1H2 Software number: 000915105AK Long coding: 303030393135313035414B5641303335303332304B314832 Trouble codes: No trouble codes found ---------------------------------------------------------------62 Rear Left Door System description: Türsteuer.HL BRM007 Software number: 4E0910802 Software version: 0110 Hardware number: 4E0959801A Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------65 Tire Pressure System description: Reifendruck 2 H01 Software number: 4E0910273 Software version: 0210 Hardware number: 4E0907273 Coding: 0212127 Trouble codes: 01521 - Tire pressure sensor Lower limit not reached static ---------------------------------------------------------------72 Rear Right DoorSystem description: Türsteuer.HR BRM007 Software number: 4E0910802 Software version: 0110 Hardware number: 4E0959802A Coding: 0028196 Trouble codes: No trouble codes found ---------------------------------------------------------------75 Telematics System description: Telematik USA1 Software number: 4E0910616 Software version: 0080 Hardware number: 4E0035616B Serial number: 0000ATD3009377 Coding: 0000005 Trouble codes: 01531 - Emerg.battery Lower limit not reached static ---------------------------------------------------------------76 Parking Assistance System description: Parkhilfe 8-Kan H12 Software number: 4E0910283A Software version: 0020 Hardware number: 4E0919283B Serial number: 08730407102439 Coding: 0001208Trouble codes: No trouble codes found
Kelby96789
06-23-2018 10:38 PM
