New 2007 A8 4.2 Sport Owner - Problems Already
Hi Fellow D3 owners,
I recently purchased a silver/black 2007 A8 4.2 WAULV44E47N003165 with 88K miles (photo attached) and had it shipped to me in the Seattle (Bellevue/Redmond) area from Southern California. The previous owner purchased the vehicle from Hoehn Audi in Calrsbad with ~30K miles on it as a CPO and had all of his service done at the dealer or an Indy mechanic called Hugo's European Car Service in Encinitas.
Sorry in advance for a long intro forum post, but I want to get started off on the right foot with my new to me A8. Much appreciation in for any advice on the car after reading my post! I have only put about 500 miles on the vehicle since purchase, and already a little frustrated.
I have owned Audi (1990 Coupe Quattro), Mercedes (1997 E420), Jeep (2002 Grand Cherokee Overland - wife) and Volvo (S60 T5 and my wife's current XC90 V8) vehicles in the past, but it has been several years since I have owned an Audi and am in the process of locating a quality mechanic to work on this vehicle. Referrals appreciated!
I had the car pre-purchase inspected by Hoehn and they noted seaps (minor) for oil/fluids and that the 20" tires needed to be replaced. Front pads ~40%. It needs a new AT shifter ribbon and I found the push button start button doesn't seem to work (stop does). I bought the car.
Most recent work by prior owner: He had the intake walnut blasted + new intake gasket for carbon build up and reset CEL again at the end of February 2016 because of multiple cylinder misfires at Hugo's. December 2015; 85K service at Hoehn, reset CEL, replace upper control arm bushings, replace driver front window regulator, replace trunk lid motor, and replace T-Stat 079-121-115-BA ($81.99 part) on "front of engine" (stuck open with ODIS fault P2181) because car was not warming up (this issue was resolved and the system tested as working correctly). April 2015, Hugo's CEL Thermostat assembly ($99.00 but no part # on invoice - so is this the same items being replaced twice) - Replace thermostat assembly reset adaptions, clear fault memory and retest. Hugo's 3/2015, new battery (H9 110ah) and replaced coolant temp sensor (water temp sender $41.16 part) to fix "coolant system performance malfunction". Hugo's - 8 new spark plugs PFR6W-TG NGK at 76K miles (75k service) 8/2014. Going back further and looking at items that are not standard maintenance; the MMI motor was remounted to not bind, coolant expansion tank replaced, a couple of door trim mouldings were replaced, and all 8 coils were replaced at 38k miles (recall item?)
On delivery, the car had a stow away rat/mouse nest and the critter(s) ate the wiring connecting the harness to the cam sensors on either side of the top of the engine (photo attached). So when the car arrived both the CEL and the EPC lights were on for the electronic system malfunction. The wiring was repaired and everything seemed to be OK, and then the CEL comes back on. I took it through emissions which I failed, and they recorded a P0047 low fuel pressure error.
This CEL went away on its own two days later and I went back and passed emissions. Then a few days later it starts running rough (misfiring) and CEL back on. Car had run smoothly prior. Other items noted, my temperature gauge is intermittent and usually is not operational or takes forever to get to operational temperature.
So I took it to the mechanic I have used recently for other vehicles (general practitioner, but works on a lot of VW/Audi). The car was due for an oil change and I wanted further guidance on the status of the vehicle CEL issues so I had the diagnostic codes dumped. The only thing I have done to date other than repairing wiring is replace tires and TPMS sensors, and had the oil changed.
my current mechanic says, "I have spent a lot of time driving and logging the car and what it is doing. The low pressure pump is fine. The duty cycle time is below 70% if memory serves for the low pressure pump.
At high RPM the high pressure pump has a "specified" and "actual pressure" reading and they need to be within 5 bar of each other and sometimes the difference is significant. I have log files that show this data. We need to replace both high pressure fuel pumps to fix this issue.
The misfire in the engine is coming from the leaking intake manifold. There are several leaks in the manifold and some of the leaks I can't do anything about. The leak between the upper and lower halves I can fix but the others I cannot. I recommend a new manifold.
The thermostat needs to be replaced and once it is, and the codes are cleared, the check engine light will not come back on for this fault. To fix it, the whole front of the vehicle needs to be removed.
There is an oil leak under the intake manifold. I see oil pooling up underneath. The oil is probably from the oil filter housing. I won't be able to confirm 100% until the manifold is off."
Diagnostics:
Monday,16,May,2016,11:38:59:41155
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 15.7.4.1
Data version: 20160216
Ross-Tech: Home
VIN: WAULV44E47N003165 License Plate: AZX1055
Mileage: 143160km-88955mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAULV44E47N003165 Mileage: 143160km-88955miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: 079-907-560-BVJ.clb
Part No SW: 4E1 910 560 A HW: 4E1 907 560
Component: 4.2l V8/4V 0040
Revision: 71H16--- Serial number: AUX3Z0F5797536
Coding: 01060009190F0120
Shop #: WSC 42286 444 85933
VCID: 2045D073F363203E5E-8074
7 Faults Found:
008577 - Performance Malfunction in Cooling System
P2181 - 008 -
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 142296 km
Time Indication: 0
Date: 2016.04.22
Time: 10:03:54
Freeze Frame:
RPM: 1911 /min
Load: 37.6 %
Speed: 93.0 km/h
Temperature: 69.00C
Temperature: 20.00C
Absolute Pres.: 1010.0 mbar
Voltage: 14.097 V
000135 - Fuel Rail/System Pressure
P0087 - 008 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 142371 km
Time Indication: 0
Date: 2016.04.23
Time: 09:44:31
Freeze Frame:
RPM: 3092 /min
Load: 74.5 %
Speed: 47.0 km/h
Temperature: 85.00C
Temperature: 30.00C
Voltage: 14.478 V
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - MIL ON
Freeze Frame:
Fault Status: 11100001
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 143130 km
Time Indication: 0
Date: 2016.05.05
Time: 10:11:31
Freeze Frame:
RPM: 807 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 19.00C
Temperature: 18.00C
Absolute Pres.: 1000.0 mbar
Voltage: 14.351 V
000773 - Cylinder 5
P0305 - 001 - Misfire Detected - Intermittent - MIL ON
Freeze Frame:
Fault Status: 10100001
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 143130 km
Time Indication: 0
Date: 2016.05.05
Time: 10:11:31
Freeze Frame:
RPM: 807 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 19.00C
Temperature: 18.00C
Voltage: 14.351 V
000772 - Cylinder 4
P0304 - 008 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143131 km
Time Indication: 0
Date: 2016.05.05
Time: 10:14:41
Freeze Frame:
RPM: 2790 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 54.00C
Temperature: 33.00C
Voltage: 14.097 V
P0087 - 002 - Too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143160 km
Time Indication: 0
Date: 2016.05.12
Time: 18:52:47
Freeze Frame:
RPM: 3759 /min
Load: 100.0 %
Speed: 92.0 km/h
Temperature: 84.00C
Temperature: 32.00C
Voltage: 13.081 V
000776 - Cylinder 8
P0308 - 001 - Misfire Detected - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143162 km
Time Indication: 0
Date: 2016.05.12
Time: 18:55:20
Freeze Frame:
RPM: 2984 /min
Load: 100.0 %
Speed: 39.0 km/h
Temperature: 92.00C
Temperature: 33.00C
Voltage: 14.097 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09L-927-760.lbl
Part No SW: 4E1 910 156 C HW: 09L 927 156 A
Component: AG6 09L 4,2lFSI USA 0010
Revision: --H01--- Serial number: 4200274
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 234FDF7FE2753B2643-8076
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H46 0510
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 2241DA7BFD6F322E48-8076
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F5797536
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58B5B893EBB3A8FE66-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071648
VCID: 244DDC63E77B3C1E3A-8070
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 732 T HW: 4E0 035 729 A
Component: Interfacebox H43 4610
Revision: 00000000 Serial number: 348FJ067504130
Coding: 0000003
Shop #: WSC 22172 444 57478
VCID: 336F2F3F5295ABA6B3-8066
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000012218
Subsystem 3 - Serial number: 0121.06.060000000100010013
Subsystem 4 - Serial number: 010013
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 H
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000099696
Coding: 0037185
VCID: 1C3DE483DF0B04DE82-8048
Subsystem 1 - Part No: 4E0 910 772 A
Component: Sitzluefter FS H02 010
Subsystem 2 - Part No: 4E0 910 772 A
Component: Sitzluefter BFS H02 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO26062006065A00000000001489
Subsystem 5 - Serial number: 000014898053000 000-SHO
Subsystem 6 - Serial number: 000-SHO26062006065A00000000
Subsystem 7 - Serial number: 65A000000000033
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E1 955 113 B
Component: ILM Fahrer H15 0230
Coding: 0143123
VCID: 3669162B41E7BE8E94-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000035
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8141698
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 D HW: 4E0 035 593
Component: SDAR SIRIUS H04 0670
Revision: 00000000 Serial number: AUZ4Z7F3029043
VCID: 2855C8539B53D87E16-807C
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 141571 km
Time Indication: 0
Date: 2016.02.29
Time: 14:48:08
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0006HAQ
Coding: 0532707
VCID: 2649C66B9147CE0E24-8072
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36FDS
Subsystem 3 - Serial number: 0001.01.0000H010000000000063
Subsystem 4 - Serial number: 00000063328RB4014A9E68U63
Subsystem 5 - Serial number: A9E68U63428RB4014A9E92S63
Subsystem 6 - Serial number: A9E92S63528RB4014A9DFB063
Subsystem 7 - Serial number: A9DFB063628RB4014A9E6B-63
Subsystem 8 - Serial number: A9E6B-63729RB4015BA7A4V63
Subsystem 9 - Serial number: BA7A4V63829RB4015BA7FF5
Subsystem 10 - Serial number: BA7FF5
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksdulenmodul H14 0040
Coding: 0012141
VCID: 65CB8167ACC10516ED-8030
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 951 C HW: 4E0 920 951 C
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F5001198
Coding: 0048263
Shop #: WSC 51068 001 1048576
VCID: 254BC167EC41C5162D-8070
Address 19: CAN Gateway Labels: 4L0-910-468.clb
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B0661781BD
Coding: F5D5DF7F307A0E
VCID: 6CDDF4434F2B345EB2-8038
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 J HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 6310
Coding: 0015510
VCID: 2A51325B855FEA6E00-807E
1 Fault Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 93
Mileage: 141731 km
Time Indication: 0
Date: 2016.03.31
Time: 18:20:10
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071658
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 C HW: 4E0 919 887 D
Component: MNS US H48 0960
Revision: 00000000 Serial number: 381EF067501160
Shop #: WSC 22172 444 11700
VCID: 2E593E4BB9B7864EDC-807A
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H04 0090
Serial number: 00000617000210
Coding: 0003477
VCID: 1D3BE987C4110DD675-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: T|rsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040606260064
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P27H08 0090
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 R HW: 4E0 035 223 G
Component: DSP-High D3 H02 0120
Revision: PROD_01 Serial number: 00000000002035
Coding: 0000026
VCID: 2C5D34438FABF45EF2-8078
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000088279
Coding: 0010111
VCID: 1E39EE8BC91716CE6C-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T159X05
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: T|rsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000922
VCID: 1F47D38FCE1D1FC667-804A
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
VCID: 2953CD578059E17609-807C
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0630
Revision: 00000000 Serial number: 396F2067539757
Coding: 0000002
VCID: 31632537A88999B6C1-8064
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000011780
Shop #: WSC 22129 444 54391
Subsystem 1 - Part No: 000 915 105 DL
Component: von VA0 341O11B0O9
Coding: 303030393135313035444C5641303334314F313142304F39
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: T|rsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000900046305
Coding: 0232125
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 136
Reset counter: 97
Mileage: 142307 km
Time Indication: 0
Date: 2016.04.22
Time: 10:12:12
Freeze Frame:
(no units): 63.0
Temperature: 16.00C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000606090115
Shop #: WSC 12336 024 394758
VCID: 346D2C23579BAC9EAA-8060
Address 6C: Back-up Cam. Labels: 4E0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J6610N3
Coding: 1120502
VCID: 5CBDA4839F8B44DE42-8008
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: T|rsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720617109074
Coding: 0221208
4 Faults Found:
01629 - Sensor for Parking-Aid; Front Left (G255)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
01626 - Sensor for Parking-Aid; Front Right (G252)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
01628 - Sensor for Parking-Aid; Front Mid-Left (G254)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
01627 - Sensor for Parking-Aid; Front Mid-Right (G253)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H13 1130
Revision: 00000000 Serial number: 00000007533869
Coding: 0010900
End-------------------------(Elapsed Time: 03:53)--------------------------
Diagnostics:
Ross-Tech: Home
7 Faults Found:
P2181 - 008 -
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 142296 km
Time Indication: 0
Date: 2016.04.22
Time: 10:03:54
Freeze Frame:
RPM: 1911 /min
Load: 37.6 %
Speed: 93.0 km/h
Temperature: 69.00C
Temperature: 20.00C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 142371 km
Time Indication: 0
Date: 2016.04.23
Time: 09:44:31
Freeze Frame:
RPM: 3092 /min
Load: 74.5 %
Speed: 47.0 km/h
Temperature: 85.00C
Temperature: 30.00C
Voltage: 14.478 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 143130 km
Time Indication: 0
Date: 2016.05.05
Time: 10:11:31
Freeze Frame:
RPM: 807 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 19.00C
Temperature: 18.00C
Voltage: 14.351 V
000773 - Cylinder 5
Freeze Frame:
Fault Priority: 0
Fault Frequency: 3
Reset counter: 255
Mileage: 143130 km
Time Indication: 0
Date: 2016.05.05
Time: 10:11:31
Freeze Frame:
RPM: 807 /min
Load: 30.2 %
Speed: 0.0 km/h
Temperature: 19.00C
Temperature: 18.00C
Voltage: 14.351 V
000772 - Cylinder 4
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143131 km
Time Indication: 0
Date: 2016.05.05
Time: 10:14:41
Freeze Frame:
RPM: 2790 /min
Load: 19.6 %
Speed: 0.0 km/h
Temperature: 54.00C
Temperature: 33.00C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143160 km
Time Indication: 0
Date: 2016.05.12
Time: 18:52:47
Freeze Frame:
RPM: 3759 /min
Load: 100.0 %
Speed: 92.0 km/h
Temperature: 84.00C
Temperature: 32.00C
Voltage: 13.081 V
000776 - Cylinder 8
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 143162 km
Time Indication: 0
Date: 2016.05.12
Time: 18:55:20
Freeze Frame:
RPM: 2984 /min
Load: 100.0 %
Speed: 39.0 km/h
Temperature: 92.00C
Temperature: 33.00C
Voltage: 14.097 V
Coding: 0000002
Coding: 0008597
Coding: 0410624
Component: ELV XXXX
Coding: 4071648
Coding: 0000003
Coding: 0037185
1 Fault Found:
Coding: 0143123
Coding: 00000035
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 10
Mileage: 141571 km
Time Indication: 0
Date: 2016.02.29
Time: 14:48:08
Coding: 0532707
Coding: 0012141
Coding: 0048263
Coding: 0015510
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 93
Mileage: 141731 km
Time Indication: 0
Date: 2016.03.31
Time: 18:20:10
Coding: 4071658
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000026
Coding: 0010111
Coding: 0032364
Revision: A32C0220
Coding: 0000922
Coding: 0000018
Coding: 0000002
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Reset counter: 97
Mileage: 142307 km
Time Indication: 0
Date: 2016.04.22
Time: 10:12:12
Freeze Frame:
(no units): 63.0
Temperature: 16.00C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 1120502
Coding: 0032364
Coding: 0221208
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 96
Mileage: 143041 km
Time Indication: 0
Date: 2016.05.04
Time: 14:18:13
Coding: 0010900
With all the work done involving CEL and intake manifold work on an 88K miles in the last few months at a Hugo's place and you still bought the car? Anyhow, it's done.
If it were me, I would study and tackle one problem at a time.
1. How do you know the leaks exist? Did the leaks contribute to the rough running? "It was running smoothly".
2. Why Thermostat needs to be replaced? Temperature stuck high or low? Temperature gauge erratic?
3. CEL is the culprit of all these work before and it didn't fix it, may be that's why the owner sold the car. You and your shop may have to shotgun to replace everything and it may not even fix the CEL. Since it never happens to me, I haven't studied about CEL, it might just be something simple. Audi A8 is a complex car with tons of sensors and control systems, it's hard to troubleshoot, but before you start tearing down an 88k miles engine to replace things that may not even fix the problem, study it first. The biggest mistake of the owner is to have HUGO to mess around with the intake manifold. I would not buy any car with any manifolds removed or replaced, it's just me.
4. It just showed that spending money for a dealer to inspect the car, just a waste of money. Buy from an honest owner who would tell you what's wrong with the car is the best.
Cheers and good luck,
Louis
Louis
