New Tires & TPMS reset
Have an 06 A8L and replaced the tires and followed instructions to reset tire pressure, but it will not reset, it has been a week since the tires were put on and I have gotten 2 yellow Tire pressure system malfunction on the info display in front of steering, has anybody had this problem with new tires?
I had this problem as soon as I turned the car on right after the new tires were replaced. After I went into the TPMS menu, I hit initzialize and the system reset to re-calibrate. Maybe when installing the tires they could have bumped or broken one of the sensors posssibly? Just a guess and is the alert on all the time? If not you might be able to get ahold of someone with a vag come incase your car's set to go off at a different or weird tire pressure that isn't correct anymore.
moonraker
02-25-2005 09:58 AM
