No Start, Need Codes Diagnosis
OK, so I had an episode where I jumped another car with mine and fried the battery management module. Replaced it, cleared the codes with the VCDS and it ran fine. Wanted to reprogram the battery and module, but VCDS was not accepting inputs.
Now, two months later, the car will not start unless I clear the codes. I have seen two diagnoses:
1. It's a steering column sensor out and it will take replacing the whole column to fix.
2. It's a battery low issue and that's causing other problems in the system.
You tell me.
Faults found:
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H02 0110
Revision: 01103502 Serial number: AUX3Z0C1511411
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BFC685EB9808FE4E-800C
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00288 - Steering Column Lock Actuator (N360)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 1
Fault Frequency: 0
Reset counter: 255
Mileage: 274528 km
Time Indication: 0
Date: 2015.09.04
Time: 07:25:46
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000013 Serial number: 00000000012514
Coding: 0037185
Shop #: WSC 06794 666 30857
VCID: 5ABBDC8D95941AEE78-800E
1 Fault Found:
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 274533 km
Time Indication: 0
Date: 2003.02.28
Time: 19:37:38
Freeze Frame:
Voltage: 13.50 V
(no units): 160.0
(no units): 255.0
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 255
Mileage: 274528 km
Time Indication: 0
Date: 2015.09.04
Time: 07:25:46
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 C
Component: MNS US H41 1100
Revision: 00000000 Serial number: 355CK037502663
Shop #: WSC 02353 785 00200
VCID: 387F66054BD8E8FEAE-806C
1 Fault Found:
00862 - Antenna for GPS Navigation (R50/R52)
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 7
Reset counter: 55
Mileage: 274506 km
Time Indication: 0
Date: 2003.02.27
Time: 22:56:50
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5FCDED998EB6FFC60F-800A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 10
Reset counter: 54
Mileage: 274458 km
Time Indication: 0
Date: 2003.02.27
Time: 05:27:41
Freeze Frame:
Speed: 0.0 km/h
Temperature: 35.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 53
Mileage: 274465 km
Time Indication: 0
Date: 2003.02.27
Time: 05:40:14
Freeze Frame:
Speed: 62.0 km/h
Temperature: 37.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
You tell me.
Faults found:
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 255
Mileage: 274528 km
Time Indication: 0
Date: 2015.09.04
Time: 07:25:46
Coding: 0037185
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 94
Mileage: 274533 km
Time Indication: 0
Date: 2003.02.28
Time: 19:37:38
Freeze Frame:
Voltage: 13.50 V
(no units): 160.0
(no units): 255.0
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
014 - Defective
Freeze Frame:
Fault Priority: 1
Fault Frequency: 0
Reset counter: 255
Mileage: 274528 km
Time Indication: 0
Date: 2015.09.04
Time: 07:25:46
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Fault Frequency: 7
Reset counter: 55
Mileage: 274506 km
Time Indication: 0
Date: 2003.02.27
Time: 22:56:50
Coding: 0212127
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Fault Frequency: 10
Reset counter: 54
Mileage: 274458 km
Time Indication: 0
Date: 2003.02.27
Time: 05:27:41
Freeze Frame:
Speed: 0.0 km/h
Temperature: 35.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 53
Mileage: 274465 km
Time Indication: 0
Date: 2003.02.27
Time: 05:40:14
Freeze Frame:
Speed: 62.0 km/h
Temperature: 37.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Just a quick one ... or two.
There is a cowl drain under the battery. What surprised me is that there is a second drain under the brake master cylinder.
If this one has water in it it will mess up the electronics, ABS, ESP and a bunch of other stuff. I cleaned both drains and ... presto, a whole bunch of issues cleared up.
I had been quoted $1,000+ to fix the ABS and steering angle sensor. Just a little drain cleaning and everything is working again.
P3081 Low Temp Indication.
If the thermostat is not getting the engine to normal temperatures, replace the thermostat.
If it does get warm and the code is active, likely the Temperature Sensor (the green one) needs replacement. These seem to be cheap too. Be sure to get anew O ring (or two).
David Goodwin (10-12-2022)
saifxnyc
9
11-30-2015 12:32 PM
Stubborn, but Happy
Audi allroad
09-12-2015 12:58 PM
CPLYONS
09-07-2015 07:19 PM
ajg617
09-06-2015 07:23 AM
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
