Sponsored by:
Sponsored by:
Offset/tire width question
Old 07-30-2015, 07:33 AM
Banned
quiksilverly's Avatar
Default Offset/tire width question
I'm playing around with different wheel widths of an 18 inch wheel and trying to make up the gap between it and the fender. I am doing this because my 15mm spacers always cause a vibrations so I would like to just get wider wheels. My questions is if my stock wheel has a 45mm offset and is 8.5 wide do I take the difference in wheel width and chop it in half and add that to the offset to calculate how much closer to the fender the outside of the wheel will be? Hate having my baby looking like a hippo from the rear.
Old 07-30-2015, 04:47 PM
AudiWorld Wiseguy
dvs_dave's Avatar
Are you using hub centric type spacers from a reputable manufacturer?
Old 07-30-2015, 10:48 PM
mishar's Avatar
Your calculation is right, but you can do better than that if you are willing to buy wider tires too. You can keep 45 mm offset, go to 9.5" rims and add 30 mm to the tire width also going for a 5% lower ratio. For example: if you have 255/45x18 go for 285/40x18 and 18x9.5 ET45 rims. This link will help you.
MonzaA5
16
11-08-2010 08:41 PM
TToplessTTs
Wheels & Tires Discussion
11-26-2006 04:11 PM
Lotusm50
Audi allroad
06-08-2004 04:11 PM
q2quest
01-27-2004 11:32 PM
rexti_98
08-21-2002 09:24 AM
Quick Reply: Offset/tire width question
