One pink headlight :-/
Yup. It won't be long until "It's dead Jim".
Look on Amazon or Ebay for the replacement lamps. Be careful though as many counterfeits exist. Lamps can be had for $50 if you shop around. Dealer charged me $75 for install which is not bad considering the work involved. I could have done it myself but just didn't want to take the chance.
If you do a search, you'll find my thread on my lamp search, etc.
Larry
Larry
Good Osram's can be found for 50-60 but I did a cheap Chinese junk bulb over two years ago for $30 and it is still blue/white and matches the one year older Osram next to it. FWIW.
I replaced both bulbs and still have exactly the same symptoms. Either swap bulb side to side first, or swap out ignitor/ballast, to ensure the bulb is/is not actually the fault before spending $$$ unnecessarily.![Mad](https://www.audiworld.com/forums/images/smilies/mad.gif)
K9
K9
Higher750
12-03-2007 08:08 AM
jvossman
01-26-2007 07:22 AM
nvr_follow
9
11-30-2006 05:36 PM
SlehStar
11
12-07-2003 07:10 AM
