Parking Brake Fault
I had the car parked at the airport for a week, the brake was not set. When I started the car the parking brake fault symbol came on. VAGCOM report is:
Address 53: Parking Brake Labels: 4E0-910-801.lbl
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000532
Shop #: WSC 02313 785 00200
1 Fault Found:
02432 - Supply Voltage for Left Parking Brake Motor (V282)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Freeze Frame:
Voltage: 10.87 V
Count: 92
Parking brake sounds likes its still working.
Any ideas?
Revision: AV1C1010
Coding: 0000532
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 41
Time Indication: 0
Freeze Frame:
Voltage: 10.87 V
Count: 92
Any ideas?
I did activate and disengage the parking brake. It sounded fine, but the fault didn't go away. I didn't try resetting it with VAGCOM, yet. The car is still covered by Audi Assured. I am a little surprised that I can't find the fault code in the Bentley manual.
after the other stuff that's been mentioned.
Go to the left rear wheel and unplug the connector for the parking brake unit (the relatively large one back there that clearly ties to the brake caliper) and then plug it back in again. Could be as simple as a dirty/slightly corroded connector. If you jack up the rear, can be done from underneath w/out removing wheel, though easier w/ wheel off. Look for any physical damage too of course.
Hello Everyone, I am new here and this may have been covered but I could not find it. I have a 2005 Audi A6 3.2L V6. Recently I had the breaks changed and now I have a "parking break malfunction". I did a self-diagnosis and this is what I got. Also, when I start driving the car after 9 KM/H I hear a straight tone that doesn't turn off until speed is below 9KM/H.
However My breaks and park break are 100% functional. It is just the beeping and the icons on my dashboard.
00473 008
electronic parking break control module - J540
Implausiable signal
static
01826 000
Steering Angel Sensor-G85-, voltage supple terminal 30
tbd
Intermittent
If anyone has any feedback on what needs to be replaced and what might the problem be. Please let me know. Thanks in Advance
00473 008
Implausiable signal
static
01826 000
tbd
Intermittent
Banned
Look for help in A6 section...
Peace.
Peace.
00473 008
Implausiable signal
static
01826 000
tbd
Intermittent
00473 008
Implausiable signal
static
01826 000
tbd
Intermittent
I'm not sure if you are referring to me (OP) or the A6 issue. ...I did as MP suggested (not the only time either). I unplugged it and plugged it back in. No more problems with it in the past 8 years.
blazej01
03-20-2019 05:27 PM
mikesd1980
03-22-2013 07:15 AM
