Partial MMI Failure Audi A8 2007
2007 Audi A8
Due to moisture from partially closed sunroof, the MMI center consul main control wheel does not work, however surrounding corner buttons still function. No problem with screen, CD/AM-FM/Telephone/Car/Navigation/Settings, or function of four corner buttons (uo to the point that the control wheel is not needed).But without control wheel many built in feature. functions are not available.
I removed and disassembled the center consul and liberally applied contact cleaner to the control panel circuit board, with no positive result. My questions are:
1.Is the main control wheel entirely mechanical, thereby eliminating a problem in the control wheel itself?
2.Assuming the circuit board is defective, does anyone have any experience with E380 control panel circuit boards sourced in China and sold on the internet?
Any additional insight or feedback would be welcomed.
Best regards,
Jay
Best regards,
Jay
AudiWorld Wiseguy
Unless you're know what you're doing and have the skills with regards electronics and IC repair, then I'm sure you'll be able to identify the damaged components and replace.
If not, then just buy a used one off eBay with a return guarantee.
2007 Audi A8
Best regards,
Jay
Best regards,
Jay
- If the center **** is the problem, the IC that connected to the switch and the connector should be checked for power and ground. Read the IC part # and google it to find power pin and ground pin. If the chip is burnt due to water, you should have a few ohms between power and ground. My guess is the coupling capacitor of the center switch is blown and shorted, that's why the switch in "PUSHED" position, therefore you can't select anything using the wheels.
I don't assume anything until it's fully tested.
![](http://i.ebayimg.com/images/g/pfcAAOSw42JZCxCG/s-l1600.jpg)
![](http://i.ebayimg.com/images/g/KkAAAOSwT-FZCxBx/s-l1600.jpg)
Cheers,
Louis
thejulianath20
14
09-06-2011 01:58 PM
brunnhizzle
09-29-2008 12:40 AM
