Power Rear sunshade problem...
It decided to stop working. Does anybody know which fuse powers this. I checked the owners manual, but it wasn't listed. It does state there is a temp switch that won't allow it to operate under 23°, but it's been in the 80's. I just wanted to check the fuse before bringing it in for this, but not all the fuses.
Thanks
Thanks
Re: Power Rear sunshade problem...
Just checked out the wiring diagram in the Bentley manual on CD. There are two fuses for the sunshade in the trunk behind the right (Battery) cover. They are:
SF5 (10A) red wire and red & blue wires go to this fuse.
SF6 (20A) red wire and red & green wires goes to this fuse.
I provided the wire colors in case the fuse holder is not marked.
Did you try both the dashboard switch as well as the one on the ceiling above the rear seat?
poopeter-el sigthief
10-14-2002 06:48 AM
