Radio cutting on and off and bluetooth stoped working
My radio works for about 2-3 minutes then it cuts off for a second or two.
It's true for AM and FM.
I also noticed that my phone does not pair up anymore.
My MMI screen is suffering badly from the stripped gears but I assume there is no correlation between the two.I plan to have the screen fixed in a few weeks.
It's been brutally cold here so I wonder if that was a factor.
Any ideas?
Any ideas?
The screen comes up with the MMi logo at startup, which I have never seen before and then the audio works fine but it does cut on and off every 2 to 3 minutes maybe.
Also the phone does not work anymore.It says it is paired but no connection.
I did reset the MMI, as well as the phone (reset to factory) with no success.
First your battery is low or was low charge it up
your scan is not good, it says 0F has malfunction then there is not there,
07 has parking aid error but that will not stop the system from working....
all the other optical devices says OK
so you shouldn't have any issues...
also your VCDS is old.....
next tip post the contents of the text in the forum not the file ill do it so someone else can have a look but keep that in mind for the future...
Contents of his scan:
Friday,16,December,2016,21:17:02:33490
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 12.12.3.0 (x64)
Data version: 20140905
VIN: WAUPN44EX7N006329 License Plate: GGGG
Mileage: 94520km-58732mi Repair Order:
Chassis Type: 4E (4L0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 11 31 15 16 17 19 34 36 37 38
42 46 47 4F 52 53 55 56 61 62 65 67 6C 72 76 77
VIN: WAUPN44EX7N006329 Mileage: 94520km/58732miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
11-Engine II -- Status: OK 0000
31-Engine other -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
34-Level Control -- Status: OK 0000
36-Seat Mem. Drvr -- Status: Malfunction 0010
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: OK 0000
55-Xenon Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
6C-Back-up Cam. -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: OK 0000
Address 01: Engine Labels: Redir Fail!
Part No SW: 4E0 910 552 A HW: 4E0 907 552
Component: 5.2L V10/4V FSI Ŗ0040
Revision: 5AH11--- Serial number: AUX3Z0F7700918
Coding: 01060009190F0160
Shop #: WSC 92602 999 59570
VCID: 204996DBF341311EBBD-8075
2 Faults Found:
001090 - EVAP Emission Control Sys
P0442 - 001 - Small Leak - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 93772 km
Time Indication: 0
Date: 2016.11.18
Time: 16:24:05
Freeze Frame:
RPM: 1541 /min
Load: 35.7 %
Speed: 31.0 km/h
Temperature: 66.0°C
Temperature: 4.0°C
Absolute Pres.: 870.0 mbar
Voltage: 13.970 V
009250 - EVAP Canister Purge Solenoid Valve (N115)
P2422 - 008 - Stuck Closed
Freeze Frame:
Fault Status: 01101000
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 94359 km
Time Indication: 0
Date: 2016.12.12
Time: 16:16:18
Freeze Frame:
RPM: 1651 /min
Load: 62.7 %
Speed: 59.0 km/h
Temperature: 60.0°C
Temperature: -3.0°C
Absolute Pres.: 880.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 K HW: 09E 927 156 B
Component: AG6 09E 5,2 FSI USA 0020
Revision: --H01--- Serial number: 0090042
Coding: 0000002
Shop #: WSC 02313 785 00200
VCID: 2B5371F78A87E2461EF-807E
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 D HW: 4E0 614 517 AB
Component: ESP 5.7 allrad H46 0500
Coding: 0001627
Shop #: WSC 02313 000 00000
VCID: 24419ACBE7592D3EDF5-8071
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F7700918
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: D8B97E3B6B9139DE03D-808D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 K HW: 4E0 035 729 A
Component: Interfacebox H43 2740
Revision: 00000000 Serial number: 348G$067504959
Coding: 0000003
VCID: 295F8BFF807BF056EC3-807C
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH03 0040
Subsystem 2 - Serial number: 00000000018207
Subsystem 3 - Serial number: 0103.08.060000000100010122˙
Subsystem 4 - Serial number: 010122˙
1 Fault Found:
01327 - Control Module for Parking Aid (J446)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 128
Reset counter: 160
Mileage: 85934 km
Time Indication: 0
Date: 2016.01.26
Time: 14:17:25
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 G
Component: KLIMAAUTOMAT 017 0450
Revision: 00000032 Serial number: 00000000103053
Coding: 0041281
VCID: 1C31A22BDF2915FE675-8049
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H15 0230
Coding: 0133104
VCID: 3665508341C5AFAE711-8063
Subsystem 1 - Part No: 4E1 910 113 C
Component: Wischer WWS D3 H60 0420
Coding: 00000037
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 A Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH13 0090
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 F HW: 4E0 035 111 A
Component: CD-Changer H44 0470
Revision: 00000000 Serial number: AUZ5ZBF8169066
Shop #: WSC 00000 000 00000
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 H HW: 4E0 035 593 D
Component: SDAR SIRIUS H06 0080
Revision: 00000000 Serial number: AUZ4Z7G0079389
VCID: 2C5172EB8F89E57E175-8079
Address 11: Engine II Labels: Redir Fail!
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0007UZM
Coding: 0532707
VCID: 264580C39165DF2EC11-8073
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36K8A
Subsystem 3 - Serial number: 0001.01.0000H0100000000000˙†63
Subsystem 4 - Serial number: 000000˙†63328RB401698B41I˙†63
Subsystem 5 - Serial number: 98B41I˙†63428RB4016978FAZ˙†63
Subsystem 6 - Serial number: 978FAZ˙†63528RB401698B6CX˙†63
Subsystem 7 - Serial number: 98B6CX˙†63628RB4016978A1N˙†63
Subsystem 8 - Serial number: 978A1N˙†63729RB40166325EK˙†63
Subsystem 9 - Serial number: 6325EK˙†63829RB401663048C˙
Subsystem 10 - Serial number: 63048C˙
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H14 0040
Coding: 0012141
VCID: E5C747CF2CE3943688B-80B0
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 901 D HW: 4E0 920 901 D
Component: KOMBIINSTR. VDO H82 0520
Revision: D03 Serial number: AUDID3F7000472
Coding: 0048363
Shop #: WSC 30295 001 1048576
VCID: 214F93DFF84B3816B43-8074
Address 19: CAN Gateway Labels: 4L0-910-468.lbl
Part No SW: 4L0 910 468 HW: 4L0 907 468
Component: J533__Gateway H06 0040
Revision: 00H06000 Serial number: 0900B067238274
Coding: F5D5DFFF307A0E
Shop #: WSC 92602 999 88005
VCID: ECD132EBCF09A57ED75-80B9
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
2 Faults Found:
01876 - Belt Height Adjustment Button (E333); Up
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 4
Fault Frequency: 8
Reset counter: 161
Mileage: 94036 km
Time Indication: 0
Date: 2016.11.30
Time: 19:40:19
01877 - Belt Height Adjustment Button (E333); Down
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 161
Mileage: 94036 km
Time Indication: 0
Date: 2016.11.30
Time: 19:40:20
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 M HW: 4E0 919 887 D
Component: MNS US H48 1100
Revision: 00000000 Serial number: 381GM067504126
VCID: 38795EBB4BD159DE63D-806D
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H05 0090
Serial number: 00000620200013
Coding: 0003477
VCID: 1D37AF2FC4331CF690B-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 D HW: 4E0 907 289 D
Component: Komfortgeraet H07 0010
Revision: 00100007 Serial number: W040607270358
Coding: 0048702
VCID: 2A5D74F3857DFB4EE59-807F
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H05 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 P HW: 4E0 035 223 F
Component: DSP-High D3 H02 0070
Revision: PROD_01 Serial number: 00000000004475
Coding: 0000026
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 B
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000001508
Coding: 0010111
VCID: 1E35A823C93507EE891-804B
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T175Y05
2 Faults Found:
02269 - No Acknowledgment from Limit-Shut Off at Display Unit Retraction
Freeze Frame:
Fault Status: 01100100
Fault Priority: 4
Fault Frequency: 9
Reset counter: 122
Mileage: 94188 km
Time Indication: 0
Date: 2016.12.05
Time: 17:33:00
02270 - No Acknowledgment from Limit-Shut Off at Display Unit Deployment
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 122
Mileage: 94264 km
Time Indication: 0
Date: 2016.12.07
Time: 17:24:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000732
VCID: 1F4B9527CE3F0EE6827-804A
Address 55: Xenon Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 F HW: 4F0 907 357 F
Component: AFS 1 H01 0020
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 M HW: 4E0 035 541 P
Component: TUNER EU/US/RDW H42 0570
Revision: 00000000 Serial number: 396G+067543856
Coding: 0000002
1 Fault Found:
00446 - Function Limitation due to Under-Voltage
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 7
Fault Frequency: 254
Reset counter: 162
Mileage: 0 km
Time Indication: 0
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000015866
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 0607310455
Coding: 344530393135313035412056413030363037333130343535
Shop #: WSC 00000 128 00289
5 Faults Found:
02272 - Quiescent Current Stage 1
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 86259 km
Time Indication: 0
Date: 2016.02.08
Time: 09:45:55
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:22
02276 - Quiescent Current Stage 5
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:33
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:43
02277 - Quiescent Current Stage 6
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:53
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 A HW: 4F0 907 273 A
Component: Reifendruck 3 H05
Revision: 00050340 Serial number: 00000700046928
Coding: 0232428
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 Q HW: 4E0 035 753 A
Component: SDS 3501 US H45 0630
Revision: 00000000 Serial number: 00000607250269
Shop #: WSC 12336 024 394758
VCID: 34616A8B57B9BDBE4F5-8061
Address 6C: Back-up Cam. Labels: 4L0-910-441.clb
Part No SW: 4E0 910 441 HW: 4L0 907 441 A
Component: J772__Rearview 0050
Revision: --H12--- Serial number: 525PA8-J67102U
Coding: 1121402
VCID: DCB1622B1FA9D5FE275-8089
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0040
Revision: 00H12000 Serial number: 08720620802985
Coding: 0221208
VCID: 234399D7E2572A06A6F-8076
End ---------------------------------------------------------------------
2 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 5
Reset counter: 255
Mileage: 93772 km
Time Indication: 0
Date: 2016.11.18
Time: 16:24:05
Freeze Frame:
RPM: 1541 /min
Load: 35.7 %
Speed: 31.0 km/h
Temperature: 66.0°C
Temperature: 4.0°C
Voltage: 13.970 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 94359 km
Time Indication: 0
Date: 2016.12.12
Time: 16:16:18
Freeze Frame:
RPM: 1651 /min
Load: 62.7 %
Speed: 59.0 km/h
Temperature: 60.0°C
Temperature: -3.0°C
Voltage: 14.224 V
Coding: 0000002
Coding: 0001627
Coding: 0410624
Component: ELV XXXX
Coding: 4071520
Coding: 0000003
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Reset counter: 160
Mileage: 85934 km
Time Indication: 0
Date: 2016.01.26
Time: 14:17:25
Coding: 0041281
Coding: 0133104
Coding: 00000037
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Coding: 0532707
Coding: 0012141
Coding: 0048363
Coding: 4071530
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 161
Mileage: 94036 km
Time Indication: 0
Date: 2016.11.30
Time: 19:40:19
Freeze Frame:
Fault Priority: 4
Fault Frequency: 8
Reset counter: 161
Mileage: 94036 km
Time Indication: 0
Date: 2016.11.30
Time: 19:40:20
Coding: 0003477
Coding: 0032364
Coding: 0048702
Coding: 0000026
Coding: 0010111
2 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 9
Reset counter: 122
Mileage: 94188 km
Time Indication: 0
Date: 2016.12.05
Time: 17:33:00
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 122
Mileage: 94264 km
Time Indication: 0
Date: 2016.12.07
Time: 17:24:00
Coding: 0032364
Revision: A32C0220
Coding: 0000732
Coding: 0000018
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Reset counter: 162
Mileage: 0 km
Time Indication: 0
5 Faults Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 7
Reset counter: 255
Mileage: 86259 km
Time Indication: 0
Date: 2016.02.08
Time: 09:45:55
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:22
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:33
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:43
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 86528 km
Time Indication: 0
Date: 2016.02.18
Time: 12:03:53
Coding: 0032364
Coding: 0232428
Coding: 1121402
Coding: 0032364
Coding: 0221208
Address 77 Telephone is missing like it was newer installed. If it was previously working that's the place to investigate. Try connecting to it directly. Also delete all those faults and perform a new scan. Some of those hopefully are just history.
I had the same problem this summer and it pissed me off every day!
I bought an optical loop and tried every component of the MMI system.....nope....nothing was faulty.
I was out of ideas and when I opened the trunk to take off the optical loop I saw a weak connection! It was the nut over the red cable down on the left at that pic
![](https://www.audiworld.com/forums/attachments/a8-s8-d3-platform-discussion-60/33263d1375578041-adding-tv-analog-tuner-questions-%24-kgrhqr-jyfco-y1in9bqpw25l-1-~~_4.jpg)
tighten up the nut ....everything's fine!
Hope it helps
Hope it helps
