Real time help, stuck at work.
#121
Guess what? Back again! Took the family to Cafe Rio for dinner- died while pulling out of the parking spot.
Luckily I did what I said I'd do, and had the tools to strip the dash down- as well as the new relay which just came in the mail today.
It started up after the new relay got put it. Here's the VCDS Scan
Tuesday,13,December,2016,18:17:12:39127
VCDS -- Windows Based VAG/VAS Emulator Running on Windows XP x86
VCDS Version: 16.8.4.2
Data version: 20161129 DS267.0
www.Ross-Tech.com
Dealer/Shop Name: ERP
VIN: WAUML44E96N019693 License Plate:
Mileage: 182100km-113151mi Repair Order: 13Dec2016
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 0F 15 16 17 19 25 34 36 37 38 42
46 47 4F 52 53 55 56 61 62 65 67 72 76 77
VIN: WAUML44E96N019693 Mileage: 182100km-113151miles
00-Steering Angle Sensor -- Status: Sporadic communication error 1000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: Malfunction 0010
03-ABS Brakes -- Status: Malfunction 1010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: OK 0000
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
0F-Digital Radio -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: Malfunction 1010
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: Malfunction 0010
4F-Centr. Electr. II -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 1010
55-Headlight Range -- Status: Malfunction 0010
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: Malfunction 0010
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 P HW: 4E0 907 560
Component: 4.2L V8/5V G 0010
Revision: --H01--- Serial number: AUX3Z0F0784333
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 2E534587B98F92326B-807A
7 Faults Found:
17981 - Left Engine Mount Solenoid Valve (N144)
P1573 - 004 - Open Circuit
Freeze Frame:
Fault Status: 01100100
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 181780 km
Time Indication: 0
Freeze Frame:
RPM: 674 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 33.0°C
Absolute Pres.: 0.0 mbar
Voltage: 13.462 V
18057 - Powertrain Data Bus
P1649 - 008 - Missing Message from ABS Controller - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.684 V
18036 - Powertrain Data Bus
P1628 - 008 - Missing Message from Steering Angle Sensor - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.557 V
29698 - Please Check Fault Codes in Comfort System Control Module (J393)
U1002 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.684 V
18061 - Please check DTC Memory of ABS Controller
P1653 - 008 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 1346 /min
Load: 43.9 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.557 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E1 910 156 E HW: 09E 927 156 B
Component: AG6 09E 4,2L5V USA 0100
Revision: --H01--- Serial number: 0077174
Coding: 0000002
VCID: 2541BAABEC79D16A9A-8070
5 Faults Found:
049412 - No Communication with Cruise Control Module
U0104 - 000 - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
Freeze Frame:
RPM: 0 /min
RPM: 224 /min
RPM: 0 /min
(no units): 23.0
(no units): 25.0
Temperature: 59.0°C
T.B. Angle: 0.0°
062245 - Unknown Error Code
U3325 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
049448 - No Communications with Parking Brake Control Module
U0128 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
049446 - No Communications with Steering Angle Sender (G85)
U0126 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
049442 - No Communication with ESP (Vehicle Dynamics) Control Module
U0122 - 000 - - Intermittent
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 B HW: 4E0 614 517 BC
Component: ESP 5.7 allrad H44 0510
Coding: 0007597
Shop #: WSC 02313 000 00000
VCID: 224BA1B7FD572652FF-8076
1 Fault Found:
01314 - Engine Control Module
013 - Check DTC Memory - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 L
Component: FBS AUDID3 H10 0190
Revision: 01904910 Serial number: AUX3Z0F0784333
Coding: 0410624
Shop #: WSC 02311 785 00200
VCID: 58BFC35FEB8BBC82D1-800C
Subsystem 1 - Part No: 4E0 905 852 E
Component: ELV 1940
2 Faults Found:
00576 - Terminal 15
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 2
Fault Frequency: 0
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
00185 - Control Circuit; Relay for Supply Voltage Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:38
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 D HW: 4E0 959 760 B
Component: Sitzmemory BFS H02 0010
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4071520
VCID: 2447A7AFE74328628D-8070
No fault code found.
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 731 B HW: 4E0 035 729
Component: Interfacebox H43 1190
Revision: 00000000 Serial number: 346AP067530666
Coding: 0000003
VCID: 204FABBFF35B3442E9-8074
Subsystem 1 - Part No: 4E0 910 611
Component: E0380 BedienteilH01 0050
Subsystem 2 - Serial number: 00000000057090
Subsystem 3 - Serial number: 0131.01.080000000100010117ÿ
Subsystem 4 - Serial number: 010117ÿ
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 B HW: 4E0 820 043 D
Component: KLIMAAUTOMAT 016 0400
Revision: 00000030 Serial number: 00000000090194
Coding: 0004417
Shop #: WSC 22198 444 64035
VCID: 1C379F4FDF3310A235-8048
2 Faults Found:
01592 - Air Quality Sensor (G238)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:05
Freeze Frame:
Temperature: 15.0°C
00819 - High Pressure Sensor (G65)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:06
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 Q HW: 4E0 907 279 Q
Component: ILM Fahrer H14 0230
Coding: 0143123
VCID: 36636DE741DFAAF223-8062
Subsystem 1 - Part No: 4E1 910 113 B
Component: Wischer WWS D3 H50 0400
Coding: 00000036
Shop #: WSC 02313
Subsystem 2 - Part No: 4E0 910 557 Labels: 8K0-955-559.CLB
Component: REGENLICHTSENSORH11 0050
Coding: 00139548
Shop #: WSC 02313
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 E HW: 4E0 035 111 A
Component: CD-Changer H44 0430
Revision: 00000000 Serial number: AUZ5ZBF7266809
Shop #: WSC 00000 000 00000
VCID: 1B359C53DA3D179A3C-804E
Address 0F: Digital Radio Labels: 4E0-910-593-SIR.lbl
Part No SW: 4E0 910 593 B HW: 4E0 035 593
Component: SDAR
Serial number: AUZ4Z7E20
VCID: 2643BDA7917FDA7293-8072
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Freeze Frame:
Raw, Form. N/A: 000 000 075
Raw, Form. N/A: 000 000 000
Address 15: Airbags Labels: 4E0-910-655-94.lbl
Part No SW: 4E0 910 655 C HW: 4E0 959 655 J
Component: Airbag 9.41 H12 4030
Revision: 91H12400 Serial number: 0037Q0004NYB
Coding: 0532707
Shop #: WSC 22198 444 84161
Subsystem 1 - Part No: 4E0 910 339
Component: BF-Gewichtsens. H01 0030
Subsystem 2 - Serial number: 36FGA
Subsystem 3 - Serial number: 0001.01.0000H0100000000000ÿ†63
Subsystem 4 - Serial number: 000000ÿ†63328RB400E1D413Eÿ†63
Subsystem 5 - Serial number: 1D413Eÿ†63428RB400E1D46DUÿ†63
Subsystem 6 - Serial number: 1D46DUÿ†63528RB400E1D8CB$ÿ†63
Subsystem 7 - Serial number: 1D8CB$ÿ†63628RB400E1D892Sÿ†63
Subsystem 8 - Serial number: 1D892Sÿ†63729RB400D76155Kÿ†63
Subsystem 9 - Serial number: 76155Kÿ†63829RB400D761B0Mÿ
Subsystem 10 - Serial number: 761B0Mÿ
2 Faults Found:
01316 - ABS Control Module
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
02095 - Component Protection Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00110000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:43:06
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenksäulenmodul H13 0040
Coding: 0012141
VCID: 65C1FAABACF9116A5A-8030
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul H07 0090
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 950 Q HW: 4E0 920 950 Q
Component: KOMBIINSTR. VDO H71 0400
Revision: D02 Serial number: AUDID3F0003789
Coding: 0048203
Shop #: WSC 46297 000 104857
VCID: 326B51F7ADB7B6D20F-8066
Address 19: CAN Gateway Labels: 4E0-910-468.clb
Part No SW: 4E0 910 468 B HW: 4E0 907 468 E
Component: Gateway H11 0090
Revision: 11 Serial number: 20003061228034
Coding: FCFE7BDD1B7904
VCID: 275DB0A39675C37AA8-8072
5 Faults Found:
01303 - Telephone Transceiver (R36)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 181934 km
Time Indication: 0
Date: 2016.12.12
Time: 17:13:40
01300 - Control Module for Navigation with CD-Rom (J401)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 181934 km
Time Indication: 0
Date: 2016.12.12
Time: 17:13:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
00473 - Control Module for Elect. Park/Hand Brake (J540)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
2 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:38
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 H HW: 4E0 907 553 F
Component: LUFTFDR.-CDC H06 4480
Coding: 0010210
VCID: 285FB39F9B6BCC02A1-807C
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:57
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:59
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H02 0010
Coding: 4071530
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 N HW: 4E0 919 887 C
Component: MNS US H45 0740
Revision: 00000000 Serial number: 355BX067561786
VCID: 387F63DF4BCB5C8231-806C
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:04
Freeze Frame:
Bin. Bits: 1100
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H03 0090
Serial number: 00000532200021
Coding: 0003477
VCID: 1D31924BC42919AAC2-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 801 B
Component: Türsteuer.FS BRM003 0100
Coding: 0032364
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 B HW: 4E0 907 289
Component: Komfortgeraet H05 0010
Revision: 00100005 Serial number: W040601160028
Coding: 0048702
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel P14H06 0070
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H04 0020
5 Faults Found:
00576 - Terminal 15
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
01366 - Opened Due to Crash Signal
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:37:31
01134 - Alarm Horn (H12)
012 - Electrical Fault in Circuit
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 254
Reset counter: 42
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:43:07
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 K HW: 4E0 035 223 A
Component: DSP-Amp.-High H13 0440
Revision: PROD_01 Serial number: 00000000006062
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:02
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 A HW: 4E0 907 280 A
Component: ILM Beifahrer H11 0070
Revision: Serial number: 00000000078354
Coding: 0010111
VCID: 1E339547C92F02B2DB-804A
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H04 0050
Subsystem 2 - Serial number: 0253440T13BT05
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:00
02258 - Door Opener Transmitter
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:00
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 B HW: 4E1 959 802 B
Component: Türsteuer.BF BRM003 0100
Coding: 0032364
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 D HW: 4E0 907 801 B
Component: EPB A4EC0230 H03 0230
Revision: --H03---
Coding: 0000532
Shop #: WSC 46297 000 1048576
5 Faults Found:
01299 - Diagnostic Interface for Data Bus (J533)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Count: 246
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 247
00576 - Terminal 15
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 41
01315 - Transmission Control Module
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 243
01321 - Control Module for Airbags (J234)
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:56
Freeze Frame:
Voltage: 11.18 V
Count: 244
Address 55: Headlight Range Labels: 4F0-910-357.lbl
Part No SW: 4F0 910 357 E HW: 4F0 907 357 E
Component: AFS 1 H01 0010
Revision: 00000001 Serial number:
Coding: 0000018
Subsystem 1 - Part No: 4F0 941 329 B
Component: AFS-Modul links H02 0020
Subsystem 2 - Part No: 4F0 941 329 B
Component: AFS-Modul rechtsH02 0020
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 F HW: 4E0 035 541 E
Component: TUNER EU/US/RDW H42 0480
Revision: 00000000 Serial number: 396AR067531923
Coding: 0000002
VCID: 2345A4B3E24D2F5AF4-8076
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 C HW: 4E0 915 181 C
Component: J0644 BEM H12 0550
Revision: 00000000 Serial number: 00000000000629
Subsystem 1 - Part No: 4E0 915 105 A
Component: von VA0 310212C07X
Coding: 344530393135313035412056413033313032313243303758
Shop #: WSC 22198 444 05017
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:05
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 801 C
Component: Türsteuer.HL BRM003 0100
Coding: 0032364
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01
Revision: 00010028 Serial number: 00000700037458
Coding: 0232125
VCID: 5FCDE8438EA54BBA90-800A
1 Fault Found:
01521 - Sensor for Tire Pressure
002 - Lower Limit Exceeded
Freeze Frame:
Fault Status: 01100010
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 181780 km
Time Indication: 0
Date: 2016.12.08
Time: 19:59:44
Freeze Frame:
Speed: 0.0 km/h
Temperature: 4.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 754 J HW: 4E0 035 753 A
Component: SDS 3501 US H45 0600
Revision: 00000000 Serial number: 00000601130281
Shop #: WSC 12336 024 394758
VCID: 2D51428BB489E92A52-8078
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 A HW: 4E0 959 802 C
Component: Türsteuer.HR BRM003 0100
Coding: 0032364
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 C HW: 4E0 919 283 C
Component: Parkhilfe 8-Kan H12 0030
Revision: 00H12000 Serial number: 08720602003332
Coding: 0201208
4 Faults Found:
01549 - Supply Voltage for Parking-Aid Sensor
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:57
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:01
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:01
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 B HW: 4E0 862 335
Component: Handyvorb2 H11 0440
Revision: 00000000 Serial number: 00000007529115
Coding: 0010900
End-------------------------(Elapsed Time: 03:59)--------------------------
www.Ross-Tech.com
Coding: 0007773
7 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 181780 km
Time Indication: 0
Freeze Frame:
RPM: 674 /min
Load: 24.7 %
Speed: 0.0 km/h
Temperature: 89.0°C
Temperature: 33.0°C
Voltage: 13.462 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.430 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 4
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.557 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: 79.0°C
Temperature: 62.0°C
Voltage: 11.684 V
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 182095 km
Time Indication: 0
Freeze Frame:
RPM: 1346 /min
Load: 43.9 %
Speed: 0.0 km/h
Temperature: 77.0°C
Temperature: 62.0°C
Voltage: 11.557 V
Coding: 0000002
5 Faults Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
Freeze Frame:
RPM: 0 /min
RPM: 224 /min
RPM: 0 /min
(no units): 23.0
(no units): 25.0
Temperature: 59.0°C
T.B. Angle: 0.0°
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 40
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Coding: 0007597
1 Fault Found:
Coding: 0410624
Component: ELV 1940
2 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:38
Coding: 4071520
Coding: 0000003
Coding: 0004417
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:05
Freeze Frame:
Temperature: 15.0°C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 81
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:06
Coding: 0143123
Coding: 00000036
Shop #: WSC 02313
Coding: 00139548
Shop #: WSC 02313
Component: SDAR
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 36
Mileage: 181779 km
Time Indication: 0
Freeze Frame:
Coding: 0532707
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:43:06
Coding: 0012141
Coding: 0048203
5 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 181934 km
Time Indication: 0
Date: 2016.12.12
Time: 17:13:40
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 80
Mileage: 181934 km
Time Indication: 0
Date: 2016.12.12
Time: 17:13:40
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Coding: 0410624
Component: ELV 1940
4E0905852E ELV 1940
2 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 5
Reset counter: 82
Mileage: 182080 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:38
Coding: 0010210
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:57
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:59
Coding: 4071530
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 2
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:04
Freeze Frame:
Bin. Bits: 1100
Coding: 0003477
Coding: 0032364
Coding: 0048702
5 Faults Found:
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:37:31
Freeze Frame:
Fault Priority: 3
Reset counter: 42
Mileage: 131072 km
Time Indication: 0
Date: 2014.08.10
Time: 11:59:07
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:54
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:43:07
Coding: 0000016
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 4
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:02
Coding: 0010111
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 7
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:00
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182092 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:00
Coding: 0032364
Revision: --H03---
Coding: 0000532
5 Faults Found:
Freeze Frame:
Fault Priority: 4
Fault Frequency: 2
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.08 V
Count: 246
Freeze Frame:
Fault Priority: 4
Fault Frequency: 6
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 247
00576 - Terminal 15
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 41
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Time Indication: 0
Freeze Frame:
Voltage: 11.18 V
Count: 243
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:56
Freeze Frame:
Voltage: 11.18 V
Count: 244
Coding: 0000018
2 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Freeze Frame:
Fault Priority: 2
Fault Frequency: 4
Reset counter: 82
Mileage: 182088 km
Time Indication: 0
Date: 2016.12.13
Time: 18:42:53
Coding: 0000002
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:05
Coding: 0032364
Coding: 0232125
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 38
Mileage: 181780 km
Time Indication: 0
Date: 2016.12.08
Time: 19:59:44
Freeze Frame:
Speed: 0.0 km/h
Temperature: 4.0°C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0032364
Coding: 0201208
4 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:55
00576 - Terminal 15
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:35:57
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:01
Freeze Frame:
Fault Priority: 4
Fault Frequency: 7
Reset counter: 82
Mileage: 182095 km
Time Indication: 0
Date: 2016.12.13
Time: 18:36:01
Coding: 0010900
#123
Everything cleared but the engine mount and alarm horn codes.
There is now a brand new VW relay in the socket- lets see how long this one lasts!![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
Johnny- jumpering 13-15 had no effect this time, no whirring, no air release, no start.
Shark- I used the key all week, no push button anything- still died.
#124
Hello Doc,
Hope all is well !
If you would, please tell again us what the number was on your OEM relay, sorry I just recalled that you posted a picture showing the "645", and I recall you stating "40AMP" relay, so here is my confusion, why would you have a 40AMP while myself and Jay have the 70AMP relay number "370", did someone else swap yours out prior, or can your relay receptacles even take the two "FAT" blades of the 370 or the 460 for that matter ???
Just trying to figure out if you needed a 70AMP all along....
Info I posted on Jay's thread.
The 645 is a 40 AMP relay with all four blade being the same size, the 370 is a 70 AMP rated relay that has two fat blades and two smaller blades, and just as the 370 is laid out so is the 460.
645 = 4H0 951 253
https://www.ecstuning.com/b-bosch-pa...h0951253a~bos/
370 = 8D0 951 253
https://www.ecstuning.com/b-mtc-part...8d0951253~mtc/
https://www.europaparts.com/fuel-pum...8e0951253.html
https://www.ecstuning.com/b-vemo-par...8do951253~vmo/
And the "460" in case you have that number.. 460 = 1K0 951 253
Relay 460 (J329 Power Supply) (A5 BRM) - 1K0951253A - 1K0951253A - IDParts.com
https://www.europaparts.com/relay-1k0951253a.html
https://www.ecstuning.com/b-genuine-...ch/1k0951253a/
Hope all is well !
645 = 4H0 951 253
370 = 8D0 951 253
Last edited by Giovanni Giovino 6.0+6.0TT; 06-06-2017 at 03:14 PM. Reason: had "465" when it is 645....
#125
I have no idea if the fatter relay would even fit.... I do recall the relay feeling 'loose' before replacement, but the lower relay is also a 645, so maybe it's the way it's supposed to be?
But, having a 40 amp in there would explain why the cheap 40 amps would burn out so quickly, and the better built 40 amps from VW are lasting longer?
Is there anyway to know for sure what should be in there? Maybe I need two 70 amp relays like you have?
#127
As an update, the car started dying again. I dug back into it and replaced both 645 relays with 307’s. The 40 amp relays held up longer than I expected. Back on 70 amp relays now... no problems this morning.
Giovanni Giovino 6.0+6.0TT (06-20-2019)
Costasz
04-03-2008 05:52 PM
