Replace 2007 S8 Steering Rack with 2008 A8 Rack
Like the title says, can I use a 2008-2010 A8 steering rack to replace the steering rack in my 2007 S8. The A8 racks are more plentiful and a whole lot cheaper.
Thanks
Mike
Thanks
Mike
Yes, I am talking about a used one. Really don't want spend big dollars for a S8 4E1422052d rack if I really don't need to. The A8 rack will work, just don't know the real difference in the two racks. It is possible that I may only need to adjust the steering rack. It is binding when the car is going straight, if you turn the wheel slightly while driving it in straight line, it will stick in that position.
I found this link online stating that the A8 rack 4E1422052C is used on the S8 in some markets.
Audi, WV, Skoda, Seat part number 4E1422052c
Mike
Mike
Still way easier than a rack change. As Mister Bally first stated, at least on older Audis like we both owned and pulled leaking racks on, the very first part they laid down at station 1 on the Audi assembly line was not the welded up body but rather the rack, building everything else it seems around it.
MP4, I was going to attempt to adjust the rack. I bought the car after it had hit a curb and the insurance company totaled it. I assume the rack was not doing this until it hit the curb. I was looking for a backup plan in case it did not work.
BASARAB, it has 96K miles, thanks for looking up the parts. It looks like the racks are the same, I guess it depends where you look for the interchange information.
Mike
Mike
Mike
Mike
![](https://cimg1.ibsrv.net/gimg/www.audiworld.com-vbulletin/2000x1493/img_20161203_115835_eb16caf677bfd52a97ace855953c557333f81a56.jpg)
, all it needed was new rack and pinion and a new fender
Looks like a nice car, what was wrong with the steering rack. I had to replace the lower control arms, air strut, tie rod end, and the wheel. My front bumber cover was not damaged. What did you pay for your S8?
Mike
Mike
We have an S8 at the shop right now that hit a curb and the rack snapped clean in two. Curiously, a new rack (has to come from Germany) is $400 cheaper than a re-built rack from Audi. And the re-built rack would require a core, and since the core is no good, there would be an additional $400 core charge for the re-built rack.
Captain Sweeney
06-06-2018 03:36 PM
