Reset air suspension after sitting for a while?
I just came back from a long vacay (gone for 3-4 weeks) and the car was sitting on bump stops front and back. I'm guessing there's some kind of power save mode where it stops auto correcting the ride heigh after a while.
Anyway, I started the car up and everything came up without issue (lights went away). Driving the car is no problem, but when i turn it off it seems to vent the front left shock back to the bump stop. I can even hear hissing from that side as the shock goes back down.
Interesting, though the car comes up to the proper height and stays there when I start it. I guess it's time to spray it down with water and look for bubbles.
I'm going through a similar experience with my wife's allroad. The reason the car pumps back up when turned on is the compressor is working to fill the air bladders and if the leak is small, it will keep it filled while you're driving. The problem with this is the compressor is working all the time to keep the system filled and eventually, will burn itself out, adding considerable expense to the repairs. If all the corners are dropping to the stops, it might be a line or valve block that's leaking air or even a faulty sensor and not the springs themselves. In my case, it's just one rear corner so I ordered a pair of Arnott air springs for my indy to install this week just in case it's not something simpler. (I can always return them if not needed).
Interesting, I'll check it tonight to see where the hissing is coming from. Hopefully just some line thing; it would be a bit odd for the shock to fail by just sitting around.
Are the S8 and A8 shocks the same? There seems to be a sport option.
They are different. You can check out the popular aftermarket air spring Arnott website to see what they look like and the differences. Also note the cost of the compressor. Multiply by 2.5-3 to estimate what the OEM parts would cost at a dealer (not including labor).
https://www.arnottindustries.com/par...17_pid174.html
Catching these early can help avoid the cost of a new (or rebuilding a) compressor.
Then there is the possibility of fused relay and valve block problems on top of that in the worst cases.
AudiWorld Wiseguy
Park the car overnight in jack mode to disable the auto leveling. In the morning it will hopefully have sunk on one corner, one end, or on all sides. This will give you a very good clue as to where the leak is.
