Reset air suspension after sitting for a while?
#11
Heh I don't have to do it overnight. With jacking mode on, as soon as i turn the car off the front left starts dropping.
#12
i helped a friend with a bad left strut i got 1 from mercedes master tech theres in florida for a rebuild strut 525 with lifetime warranty ... they also have listing on ebay but i called them directly to save even more
good luck and if it has a leak i say dont drive as your pump will go out which is another 7 to 800
#13
#14
Is it normal for the car to auto-level, when parked on a slope?
When I park my car in my driveway that slopes, after about a day I notice my car sitting with the rear lowered, as of to maintain a level body, is this the case? Or should I suspect a leak?
#16
AudiWorld Wiseguy
It doesn't try to level the body "in space" otherwise parking the car on a slope would result in it doing crazy things.
So what I'm saying is, yes you probably have a leak if it's *** is on the ground after you've left it for a while. Try the jacking mode trick to see if that helps identify where the issue is.
#18
Edit: what's the Jack mode trick? Did not find anything when I searched
#19
I Will Have to park it overnight on level ground to see if that is the case, bought the car last week with warranty and the compressor was recently changed, abit surprising if there is a leak and they didn't fix it when changing compressor.
#20
There is a seller on eBay selling new aftermarket shocks for the D3 model.
The shocks look correct, the price is 950/pair. They are cheaper than the remanufactured Audi shocks. But spending close to 1000.00 on an unknown is scary. These are most likely Chinese knockoffs.
The seller is Am-Motorsports. They sell a lot of stuff on eBay. Couple thousand items each month. Never dealt with them personally.
