retro ski bag
Just brought 2006 A8 and found ski bag on ebay that I brought.
Anyone have info on installing it? Saw diagram on removing seat back but do I need to remove it to install??
If you do figure out how to install it, please let us know. It seems ski bags are less common on A8, unlike the A6's and A4's.
Do you guys have that passage or you have to cut that first?
Ski bags should be very cheap (~$50) at dealers because they are on sale for quite some time.
Having just removed the back seat from my 2004 A8L without the ski-bag option (see "Help!-Locked out of trunk" recent post) fitting the bag won't be difficult, but neither is taking out the seat which will give you more room to do everything.
With regards to necessary mods, behind the rear armrest is a flap of leather that simply pulls out - it is not stitched or clipped to anything. Behind that is a piece of rubber/foam type material, again not attached to anything, and behind that is the "port" for the opening which is a rectangular piece of plastic that clips into the trunk frame.
Behind this is a piece of foam that runs almost the width of the rear seat. You will need to cut this with a sharp blade. Do the left and right side and the bottom and you will create a "flap" that should tuck neatly back into place when you are not using the ski bag.
Hope this helps.
Hope this helps.
Hope this helps.[/QUOTE]
It was very very easy, as stated, just pulled out out material and padding and plastic cover piece came right out. I marked trunk material with matker from inside and took it out to make perfect cut.(not necessary) Ski frame just snapped in place with a little push on each side; then inner frame just snapped in too. I love audi. Ski bag I got matches my interior and only cost $125.00. Only tool needed was something to cut trunk material!!!
Got Ski bag used out of Denver. Other parts on ebay.
Has Ebay store-- http://stores.ebay.com/europeanautoparts
Thanks for this!!!!
Sorry for bumping the thread but I am curious if you guys have any pictures of the install?
Also, any ideas about how many pairs of skiis can one get though the hatch? I have found that 84" pieces can be passed through the hatch.
Can the install be similar to the Phaetons?
VWVortex.com - okay....so how do you get the ski bag folded back in?
