Roof Electronics: J519 Module
Anybody know where this module is located? Scanned the car today and received vag code 00457 Control Module for Network (J519). Haven't noticed anything out the ordinary besides the interior lights flickering slightly when at idle and the sunroof does not open. Sometimes the gas door doesn't open when I press the button. Battery is new and good, tested at 12.71 volts and is coded properly.
you can get a used one for a pittance.
just make sure is the same or later version.
have a copy of your current coding.
if you post your vcd scan might be helpful
Hey Storka, I see a part number on eBay that is 4e0910289 for Multifunction control module (Audi A8 03-09). Could this be the correct part number instead of the one you gave?
Not sure I thought it was 4E0 907 279 as this is what I replaced with updated model for rain light sensors that are coded in the roof module.
Read through this and decide
Upgrade to rain and light sensor A8 4E 2005 | Audi Forum
Maybe a vcd readout would show your problem
00457 - Ross-Tech Wiki
