rougue headlight washer jet
#12
Try headlight spray and watch which light is coming on. I bet you that side marker is coming on instead headlight sprayer. Your guy mixed those two close harnesses.
#14
If replacment is really the only option and you dont care I would just acess the washer pump for the headlight washer and unplug it. Then force that little bastard back down. Worst remove bumper, remove washer unit, dismantle and see wtf
#16
Banned
as Mishar has said.
one would think that by removing the fuse for said washer and it still operates, It must be wired into the lighting as in the marker light on the bumper or something to do with lighting...
Does it come on with parking lights only, or when you move from parking to headlight, or have you not tried that ?
Try parking lights only then fog then headlights.
Did you pull and hold the washer stalk while someone else checked to see which light or lights came on, Please do this and report back.
Also, are all lights function properly ?
Maybe your guy did some splicing with butt connectors and it is wired wrong, it may look right as to the connector ends, but wired wrong in the harness.......
#17
as Mishar has said.
So I think that as JohnnyJ said I think my guy didnt some incorrect splicing so I guess the core question relates to (2) above ... can anyone confirm if there is a fuse dedicated to the washers as my only practical cost effective course of action is to disable either by fuse or just unplug (removing front bumper arrrgggggg)
#18
Man, check your logic. If it is on some special sprayer fuse it wouldn't come out with lights. If it is out with lights it must be on a light fuse.
You said you checked corner lights while actuating washers. Was the other washer out and spraying?
#19
it comes out if I ONLY turn on headlights (HALF THE NORMALLY REQUIRED ACTION)..... my question was trying to confirm if there was supposed to be a fuse dedicated to the washer
#20
It was clear what happens when you turn on lights from the first post. It's not clear what happens when you actuate headlights sprayer with windshield washer.
