RSE wiring question...
#11
But there in lay the mystery...
Hello Louis & 91Q,
Yes Louis, you would be correct, BUT what Nut is asking is for someone to pinpoint exactly which wire is the ignition switched wire on the RSE main unit plug/harness so that he may tap into and set it up for power when the rest of the vehicle is off, he likes to party in the back seat !!!
So Nut,
As Louis stated, that may be your only way to find that lead, pull the plug and check all the wires and note their reading, then turn on the key and do it again, and pinpoint that wire, then pull the fuse as a double check to test again.
So Nut,
I dont know if there is a source for the RSE wiring diagram or not but the issue is moot because I would not know how to read the thing. That's why I am searching for anecdotal info.
#13
OK, here's the fuse info...
Here is a detail I dont understand. In that plug there is a red/white wire and a red/yellow wire. The red/white wire is hot even with the ignition OFF. The red/yellow wire is not hot with the ignition OFF but becomes hot when the ignition is turned ON; and that would seem to identify it as the wire I need, BUT, the red/yellow wire stays hot even when the ignition is then switched OFF.
That is puzzling, I dont understand the connection (no pun intended) and I dont know what eventually causes that wire to return to the switched mode again.
I hope these clues help.
Waggin
08-07-2007 06:54 AM
bsewall
04-12-2004 04:17 PM
HooliganDrew
06-10-2002 11:48 AM
