Run hot
The most common leak is the reservoir, if I recall. You will want to source the leak, if it's lost enough to cause overheating, there will be a clear trail of residue leading up to the leak. Start from the bottom and work your way up, where the residue trail ends will be your leak. Should be pinkish in color. Even after topping the coolant back off, be vigilant in both checking the levels and monitoring the temperature. The lower levels of coolant may be a symptom, not necessarily the cause. Do not under any circumstances drive it if it's getting hot, it doesn't matter if you're a mile from home. Just stop immediately, as soon as you are out of the lane of traffic.
LosGatosS4
16
10-10-2003 12:56 PM
sissupr
06-23-2003 07:38 AM
Kirath ¾-B0§t0n
10-30-2002 12:06 PM
