S8 brake rotor options
Good evening,
Does anyone know if someone makes aftermarket rotors with aluminum hats? Guess I am asking if anyone makes a 2 piece rotors for the S8.
Thanks
Thanks
Hi,
So Auchtuning has offered me a full set of Stop tech rotors for $680 shipped. They have painted and drilled hub hats and can be slotted, if desired. I think I might give them a whirl, if I cannot find aluminium 2-piece Ina couple days.
http://shop.achtuning.com/StopTech-1...udi-D3-S8.aspx
That's way more than OEM and they are most likely not better than OEM. Especially if they make them in China.
http://www.stoptech.com/products/rot...ortstop-rotors
Anyway, made in Japan used to be a bad sign of quality...
The RS6 and A8 are both 335x22 mm, although the RS6 rears list for 350 a piece, plus theyre directional. I recently replaced a set and they truly are a race rotor, super light and very well made.
Edit: Note there is a vin cutoff in 05, early ones had smaller rears, to 005001, which were 310x22
I wish it was an option. This is for an s8, which uses a 385mm rotor.
