Sagging driver's door
Just noticed that the driver's door is sagging on my A8. The hinge also makes a popping sound. Inspected the lower hinge and both door side torx bolts are stripped. Wondering if I remove door card can I access bolts and put on nuts? Or is that area sealed and should I try a heli-coil or time-serts?
You will most probably have to remove the door card anyway so you may as well do it first and have a look as I can't remember what it looks like but logic says to me you would have to. It only takes 10-15 mins if you have the right toolsto take the door card off but buy some spare clips as some may snap.
neockder
06-04-2011 01:54 AM
90/90Qs
06-02-2006 04:21 PM
