Starter about to die? or just more technogremlins?
Hi Guys, Just to remind you Im in the Uk. Car is a 2004 3.7 v8 A8 Quattro. 134k miles.
So i leave the car overnight on my girlfriends drive (on a slight gradient nose up).
I come back to it the next day and she wont crank. Keyless works, interior lights work, seat and wheel adjust, dash lights up but no crank on button push. I try the key. No luck. I stop and start the ignition maybe a dozen times with a combination of button/key. Nothing. I disconnect the battery and re connect. Apart from putting the dash language back into english again (which has been bugging me) no crank. I put it through its gear selection. i wiggle the gear stick. I lock and unlock the car. I push the car down the road onto a level surface. Nothing.
So it gets recovered to my mechanic. It sits on his drive all night. The next day i drive over in another car with the second key just to eliminate any immobiliser issues etc.
Second key no better but then on the second try it starts! I lock the car and try the original key... it starts!
Its starts perfectly with either key for 5 days. Then last night it fails to start again.... I remember reading on a forum that if you insert the key in the ignition and turn it left for a while and then right it will start. I try it... nothing... i try again leaving it tuned left for about 10 seconds.... it starts!
Started all day today.
When my mechanic pulled the codes he got - 19510 Starter will not turn Jammed or electrical malfunction P3054 Upper limit reached - intermittent.
Only thing that ties the two instances together is freezing temperatures.
Car has a new battery (about a month since install) recoded etc. Car has been behaving perfectly (apart from some dash words in german) since the new batt.
Any ideas? Its hard to know where to start.... ill happily change the starter but Im not convinced its the actual problem.
many thanks in advance
Stoosh
Stoosh
I posted my 2004 A8 starter saga here a little over two years ago. Like the sticky says, use the search function and perform a diagnostic scan. It actually will tell you if a no crank condition was caused by the starter or not.
Otherwise we are guessing. Also, like the sticky says, use standard automotive troubleshooting techniques to figure out the problem.
Next time you have a no-start condition; have someon listen under the hood or below the car (lower cover off) and when you attempt to start, if a faint "click" is heard from the starter solenoid; the starter is likely bad. However, you should verify that the power cable from the battery is good (voltmeter required).
No "click"? verify the solenoid control wire is getting 12 volt power when a start is attempted. If not, figure out why.
Service manual, diagnostic interface, pc and software is required. Otherwise, pay someone to troubleshoot & repair for you.
Not sure if you can access the starter on a 3.7 but the net time it does not start, have someone tap on the starter while you are trying to start the car. If it starts, its the starter.
I had the same issue... replaced my brake switch and have not had an issue since. Ross Tech says that this could potentially be a solution. Try that first... it is easy and cheap.
Phil
Phil
Hi, i had the same problem on my S8. try to take of the Positive cable on the battery, not the end that is connected direct to the battery, take the other end that goes to the little box, grind it so the connector is clean, and try again. Look and touch the other connectors if stil not working to see any mis contact.
"Box" "called Bracket battery overloadprotect fuse automat" partNo: 4E0971845F
![](https://cimg7.ibsrv.net/gimg/www.audiworld.com-vbulletin/1602x706/battery_0094fdec62380592de1b87d07976d1a72bb41eb6.jpg)
Sorry for the late response guys. Ive been dealing with some personal stuff. Thanks so much for the posts.
I have a few questions....
Mr Bally - What is a "sticky" and where is a diagnosive scan performed? i dont have a vag com. ?
Philc98 - What is the "brake switch" and where is it located?
Bangeria - where is that relay and what is its function? im presuming its the ignition Circuit.
and lastly, has anyone heard of this procedure of turning the ignition key left? i know there used to be a throttle body adaption procedure on my D2 that used this method... seems odd that whenever i do it it starts!
many thanks to you all. (and for your excellent diagram Alexxelax)
Sticky is the thread "stuck" to the top of the D3 A8 forum.
https://www.audiworld.com/forums/a8-...-read-2877219/
Now the car wont start at all. So i had a guy come over with VCDS. He pulled these attached codes (Log1). then he cleared them and scanned agin after ignition (log2).
By the second read the energy management waring was flashing up. I suppose to be expected as ive been trying to start the car for 2 days.
I can hear a faint click as the ignition is turned down near the starter so Im more convinced now that this is the problem.
Anyway if anybody spots anything interesting please let me know. Many thanks
jamie
LOG 1
Friday,20,March,2015,12:40:03:13569
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1
Data version: 20150130
VIN: WAUZZZ4E03N008546 License Plate: OVO3FTGX
Mileage: 217860km-135371mi Repair Order: 1
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 13 15 16 17 19 1D 1E 25 28 34 36 37
38 42 46 47 4F 52 53 55 56 57 61 62 67 72 76 77
VIN: WAUZZZ4E03N008546 Mileage: 217860km-135371miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: OK 0000
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: OK 0000
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: Malfunction 0010
09-Cent. Elect. -- Status: OK 0000
13-Auto Dist. Reg -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: Malfunction 0010
1D-Driver Ident. -- Status: Malfunction 0010
1E-Media Player 2 -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
28-HVAC, Rear -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: Malfunction 0010
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
57-TV Tuner -- Status: OK 0000
61-Battery Regul. -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
67-Voice Control -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
76-Park Assist -- Status: OK 0000
77-Telephone -- Status: Sporadic communication error 1000
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 H HW: 4E0 907 560
Component: 3.7L V8/5V A 0010
Revision: 00000000 Serial number: AUX3Z0C2311792
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 2643499791D20C1134C-8073
No fault code found.
Readiness: 0110 1101
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 D HW: 09E 927 156 A
Component: AG6 09E 3,7L5V RdW 0060
Coding: 0000001
VCID: 23455083E2E0F939532-8076
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 21495A8BF8FCEB2941E-8074
2 Faults Found:
00003 - Control Module
014 - Defective
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - -
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 K
Component: FBS AUDID3 H07 0160
Revision: 01604707 Serial number: AUX3Z0C2311792
Coding: 0411648
Shop #: WSC 00196 210 60652
VCID: 58BF376FEB266AE1760-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0050
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 4063328
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 A HW: 4E0 035 729 A
Component: Interfacebox H43 0290
Revision: 00000000 Serial number: 300C7037517330
Coding: 0000000
Shop #: WSC 00000 000 00000
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318LW027503658
Subsystem 3 - Serial number: ˇˇ20.12.02ˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇ
Subsystem 4 - Serial number: ˇˇˇˇˇˇˇ
2 Faults Found:
02084 - Component Protection
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 01100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
01042 - Control Module; Not Coded
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000014 Serial number: 00000000013264
Coding: 0020529
Shop #: WSC 02311 785 00200
VCID: 5ABB2D67952A78F1404-800F
10 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 189
Reset counter: 149
Mileage: 216158 km
Time Indication: 0
Date: 2015.01.15
Time: 10:36:13
Freeze Frame:
Temperature: 23.0*C
00065 - Rear Left Footwell Heater (Z42)
012 - Electrical Fault in Circuit - Intermittent
Freeze Frame:
Fault Status: 00101100
Fault Priority: 3
Fault Frequency: 179
Reset counter: 188
Mileage: 216158 km
Time Indication: 0
Date: 2015.01.15
Time: 10:47:56
Freeze Frame:
Voltage: 13.60 V
00066 - Rear Right Footwell Heater (Z43)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 254
Reset counter: 188
Mileage: 216160 km
Time Indication: 0
Date: 2015.01.15
Time: 10:53:15
Freeze Frame:
Voltage: 13.90 V
01852 - Position Sensor; Defrost/Upper Body Shut-Off Flap Motor; Left Front (G318)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 6
Reset counter: 183
Mileage: 216213 km
Time Indication: 0
Date: 2015.01.16
Time: 14:54:33
Freeze Frame:
Voltage: 13.90 V
(no units): 146.0
(no units): 255.0
01857 - Air Outlet Sensor; Middle Left (G347)
007 - Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00100111
Fault Priority: 3
Fault Frequency: 2
Reset counter: 153
Mileage: 216514 km
Time Indication: 0
Date: 2015.01.19
Time: 09:30:58
01858 - Air Outlet Sensor; Right Center (G348)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 216514 km
Time Indication: 0
Date: 2015.01.19
Time: 09:30:58
01869 - Rear Left Cold / Warm Air Outlet Motor Position Sensor (G351)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 217057 km
Time Indication: 0
Date: 2015.02.16
Time: 14:50:49
Freeze Frame:
Voltage: 14.10 V
(no units): 120.0
(no units): 255.0
00716 - Air recirculation Flap Positioning Motor (V113)
003 - Mechanical Failure - Intermittent
Freeze Frame:
Fault Status: 00100011
Fault Priority: 3
Fault Frequency: 5
Reset counter: 188
Mileage: 217059 km
Time Indication: 0
Date: 2015.02.16
Time: 15:22:02
Freeze Frame:
Voltage: 13.80 V
Temperature: 23.0*C
(no units): 100.0
(no units): 76.0
Temperature: -78.0*C
00732 - Potentiometer in Positioning Motor for Right-Hand Footwell Flap (G140)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 217862 km
Time Indication: 0
Date: 2015.03.18
Time: 18:28:56
Freeze Frame:
Voltage: 11.60 V
(no units): 100.0
(no units): 255.0
01206 - Signal for Duration of Ignition Off Time
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 217862 km
Time Indication: 0
Date: 2015.03.18
Time: 18:28:56
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 C HW: 4E0 907 279 C
Component: ILM Fahrer H11 0090
Coding: 0111001
VCID: 285F47AF9BC61A61060-807D
Subsystem 1 - Part No: 4E2 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 13: Auto Dist. Reg Labels: None
Part No SW: 4E0 910 561 C HW: 4E0 907 561 C
Component: ABSTANDSREGELUNG 0010
Coding: 0021154
VCID: 224B5587FDFAF031584-8077
1 Fault Found:
01316 - ABS Control Module
013 - Check DTC Memory - MIL ON
Freeze Frame:
Fault Status: 11111101
Fault Priority: 5
Fault Frequency: 14
Reset counter: 149
Mileage: 216548 km
Time Indication: 0
Date: 2015.01.24
Time: 10:08:00
Freeze Frame:
Temperature: 5.0*C
Voltage: 10.88 V
Bin. Bits: 00000010
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
VCID: 63C51083A260B939132-8036
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200)
001 - Upper Limit Exceeded - MIL ON
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549
Component: Lenks‰ulenmodul H09 0030
Coding: 0112151
VCID: 65C10E9BAC54C709FD6-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 930 HW: 4E0 920 980
Component: KOMBIINSTR. VDO H49 0060
Revision: D07 Serial number: AUDID3C2000053
Coding: 0001403
Shop #: WSC 00485 067 57207
VCID: 5FCD1C738E089DD937A-800A
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 HW: 4E0 907 468 B
Component: Gateway H06 0050
Revision: 06 Serial number: 00004028140024
Coding: FEFF7FDC2B7504
Shop #: WSC 00000 128 00289
2 Faults Found:
01303 - Telephone Transceiver (R36)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:12
00384 - Optical Databus
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00101011
Fault Priority: 5
Fault Frequency: 3
Reset counter: 189
Mileage: 217150 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:02
Address 1D: Driver Ident. Labels: 4E0-910-218.lbl
Part No SW: 4E0 910 218 HW: 4E2 905 218
Component: FPI_1 H04 0060
Revision: 06000104 Serial number: 07022003074633
VCID: 5EB32177890294D13CC-800B
1 Fault Found:
02540 - Driver Identification Sensor Defective or Dirty (G455)
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 0
Reset counter: 171
Mileage: 217136 km
Time Indication: 0
Date: 2015.02.27
Time: 15:17:10
Address 1E: Media Player 2 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 D HW: 4E0 035 111 A
Component: CD-Changer H43 0340
Revision: 00000000 Serial number: AUZ5ZBD6000665
VCID: 1A3B6D67D5AAB8F1804-804F
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0411648
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
00668 - Supply Voltage Terminal 30
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 0
Reset counter: 189
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 21:59:46
Address 28: HVAC, Rear Labels: None
Part No SW: 4E0 910 158 HW: 4E0 919 158
Component: KLIMA-STG. FOND 015 0170
Revision: 00000009 Serial number: 00000000005306
Coding: 0000000
VCID: 61C91A8BB87CAB2901E-8034
1 Fault Found:
01863 - Air Outlet Motor; Rear Left (V218)
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 D HW: 4E0 907 553 D
Component: LUFTFDR.-CDC H04 6230
Coding: 0015500
VCID: 2447539FE7EEFE012A8-8071
7 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
008 - Implausible Signal - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 61
Reset counter: 255
Mileage: 216813 km
Time Indication: 0
Date: 2015.01.28
Time: 18:57:42
01400 - Suspension Level Control
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 216325 km
Time Indication: 0
Date: 2015.01.19
Time: 06:45:06
01598 - Drive Battery Voltage
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 255
Mileage: 207088 km
Time Indication: 0
Date: 2013.12.12
Time: 08:10:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 207088 km
Time Indication: 0
Date: 2013.12.15
Time: 11:18:12
00778 - Steering Angle Sensor (G85)
Freeze Frame:
Fault Status: 11101000
Fault Priority: 3
Fault Frequency: 34
Reset counter: 149
Mileage: 217150 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:21
00456 - Control Module for Access and Start Control (J518)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 217352 km
Time Indication: 0
Date: 2015.03.13
Time: 12:22:05
01398 - Signal Conductor for Central Locking; Doors Open
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 207105 km
Time Indication: 0
Date: 2003.03.10
Time: 07:48:14
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0050
Coding: 4063342
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 888 P HW: 4E0 919 887 C
Component: MNS ECE H41 1060
Revision: 00000000 Serial number: 305CL037531289
VCID: 3B7588E37A50A1F97B2-806E
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135 A
Component: Dachknoten D3 H01 0080
Serial number: 00000304100064
Coding: 0233408
VCID: 1D31667BC484CFC9656-8048
1 Fault Found:
02138 - Control Circuit for Front Right Interior Lights
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 189
Mileage: 217084 km
Time Indication: 0
Date: 2015.02.24
Time: 21:07:00
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 802
Component: T¸rsteuer.FS BRM004 0080
Coding: 0026918
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040303210022
Coding: 0004313
VCID: 275D449396D815190FA-8072
Subsystem 1 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
1 Fault Found:
00892 - Switch for Trunk Closing Cylinder (F248)
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 189
Mileage: 215917 km
Time Indication: 0
Date: 2015.01.08
Time: 18:47:43
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 A HW: 4E0 035 223 A
Component: DSP-Amp.-High H12 0140
Revision: PROD_01O Serial number: 00000000191466
Coding: 0000027
VCID: 1B356863DA90C1F99B2-804E
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H06 0060
Revision: Serial number: 00000000011691
Coding: 0010111
VCID: 5DB1267B84048FC9256-8008
Subsystem 1 - Part No: 4E0 910 511
Component: UGDO HL ECE H04 0030
Subsystem 2 - Serial number: VK4975T06H3E
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E2 959 801
Component: T¸rsteuer.BF BRM004 0080
Coding: 0026918
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000331
Shop #: WSC 76873 873 66865
2 Faults Found:
02596 - Rear Brake Pads Worn
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 8
Reset counter: 187
Mileage: 217296 km
Time Indication: 0
Date: 2015.03.12
Time: 13:37:48
Freeze Frame:
Voltage: 12.94 V
Count: 236
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Revision: 00000001 Serial number:
Coding: 0000002
VCID: 62CB1587BD7AB031184-8037
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0180
Revision: 00000000 Serial number: 304CD037520707
Coding: 0000001
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 02:45:20
Address 57: TV Tuner Labels: 4E0-910-146.clb
Part No SW: 4E0 910 146 HW: 4E0 919 146
Component: TV analog TUNER H11 0140
Revision: 00000026 Serial number: 00000000001413
Coding: 0001003
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000003960
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2803311791
Coding: 303030393135313035414B56413032383033333131373931
Shop #: WSC 00031 210 91012
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: T¸rsteuer.HL BRM004 0080
Coding: 0026918
Address 67: Voice Control Labels: 4E0-910-75x-67.lbl
Part No SW: 4E0 910 753 B HW: 4E0 035 753
Component: SDS 3502 UK H42 0190
Revision: 00000000 Serial number: 00000302190417
Shop #: WSC 12336 024 394758
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: T¸rsteuer.HR BRM004 0080
Coding: 0026918
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0101008
VCID: 60CF1F8FB376A2210E0-8035
Address 77: Telephone Labels: 4E0-910-333.lbl
Part No SW: 4E0 910 333 B HW: 4E0 862 333 B
Component: TELEFONMODUL EU 0180
Revision: 00000003 Serial number: T2AUD3070700RM
Coding: 0000004
VCID: 1E336177C982D4D17CC-804B
End-------------------------(Elapsed Time: 03:37)--------------------------
LOG 2
Friday,20,March,2015,13:12:52:13569
VIN: WAUZZZ4E03N008546 License Plate: 0V03FGX
Mileage: 217860km-135371mi Repair Order: 12
01-Engine -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
19-CAN Gateway -- Status: OK 0000
1D-Driver Ident. -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
38-Roof Electronics -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
56-Radio -- Status: OK 0000
61-Battery Regul. -- Status: Malfunction 0010
77-Telephone -- Status: OK 0000
Coding: 0011773
1 Fault Found:
19510 - Starter Will Not Turn
P3054 - 001 - Jammed or Electrical Malfunction
Coding: 0000001
Coding: 0008597
2 Faults Found:
014 - Defective
000 - -
Coding: 0411648
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 189
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 22:30:10
Coding: 4063328
Coding: 0000000
2 Faults Found:
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Coding: 0020529
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:07
Freeze Frame:
Temperature: 13.0*C
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Freeze Frame:
Voltage: 11.10 V
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Coding: 0111001
Coding: 00000030
Shop #: WSC 02311
Coding: 0021154
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 149
Mileage: 217860 km
Time Indication: 0
Date: 2003.02.27
Time: 22:15:00
Freeze Frame:
Temperature: 21.0*C
Voltage: 10.75 V
Bin. Bits: 00000000
Coding: 0431707
1 Fault Found:
Coding: 0112151
Coding: 0001403
Coding: 0411648
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 3
Reset counter: 149
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 22:30:10
Coding: 0000000
1 Fault Found:
Coding: 0015500
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:24:36
Coding: 4063342
Coding: 0233408
Coding: 0026918
Coding: 0004313
Coding: 0000027
Coding: 0010111
Coding: 0026918
Revision: AV1C1010
Coding: 0000331
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0001003
4 Faults Found:
02276 - Quiescent Current Stage 5
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:31:05
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:19
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:29
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:49
Coding: 0026918
Coding: 0026918
Coding: 0101008
Coding: 0000004
End-------------------------(Elapsed Time: 03:34)--------------------------
jamie
LOG 1
Coding: 0011773
Coding: 0000001
Coding: 0008597
2 Faults Found:
014 - Defective
000 - -
Coding: 0411648
Component: ELV XXXX
Coding: 4063328
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Coding: 0020529
10 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Reset counter: 149
Mileage: 216158 km
Time Indication: 0
Date: 2015.01.15
Time: 10:36:13
Freeze Frame:
Temperature: 23.0*C
Freeze Frame:
Fault Priority: 3
Reset counter: 188
Mileage: 216158 km
Time Indication: 0
Date: 2015.01.15
Time: 10:47:56
Freeze Frame:
Voltage: 13.60 V
Freeze Frame:
Fault Priority: 3
Reset counter: 188
Mileage: 216160 km
Time Indication: 0
Date: 2015.01.15
Time: 10:53:15
Freeze Frame:
Voltage: 13.90 V
Freeze Frame:
Fault Priority: 3
Fault Frequency: 6
Reset counter: 183
Mileage: 216213 km
Time Indication: 0
Date: 2015.01.16
Time: 14:54:33
Freeze Frame:
Voltage: 13.90 V
(no units): 146.0
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 153
Mileage: 216514 km
Time Indication: 0
Date: 2015.01.19
Time: 09:30:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 153
Mileage: 216514 km
Time Indication: 0
Date: 2015.01.19
Time: 09:30:58
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 165
Mileage: 217057 km
Time Indication: 0
Date: 2015.02.16
Time: 14:50:49
Freeze Frame:
Voltage: 14.10 V
(no units): 120.0
(no units): 255.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 5
Reset counter: 188
Mileage: 217059 km
Time Indication: 0
Date: 2015.02.16
Time: 15:22:02
Freeze Frame:
Voltage: 13.80 V
Temperature: 23.0*C
(no units): 100.0
(no units): 76.0
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 217862 km
Time Indication: 0
Date: 2015.03.18
Time: 18:28:56
Freeze Frame:
Voltage: 11.60 V
(no units): 100.0
(no units): 255.0
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 188
Mileage: 217862 km
Time Indication: 0
Date: 2015.03.18
Time: 18:28:56
Coding: 0111001
Coding: 00000030
Shop #: WSC 02311
Coding: 0021154
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 14
Reset counter: 149
Mileage: 216548 km
Time Indication: 0
Date: 2015.01.24
Time: 10:08:00
Freeze Frame:
Temperature: 5.0*C
Voltage: 10.88 V
Bin. Bits: 00000010
Coding: 0431707
1 Fault Found:
Coding: 0112151
Coding: 0001403
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:12
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 189
Mileage: 217150 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:02
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 0
Reset counter: 171
Mileage: 217136 km
Time Indication: 0
Date: 2015.02.27
Time: 15:17:10
Coding: 0411648
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 0
Reset counter: 189
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 21:59:46
Coding: 0000000
1 Fault Found:
Coding: 0015500
7 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 61
Reset counter: 255
Mileage: 216813 km
Time Indication: 0
Date: 2015.01.28
Time: 18:57:42
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 216325 km
Time Indication: 0
Date: 2015.01.19
Time: 06:45:06
Freeze Frame:
Fault Priority: 4
Fault Frequency: 3
Reset counter: 255
Mileage: 207088 km
Time Indication: 0
Date: 2013.12.12
Time: 08:10:42
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 255
Mileage: 207088 km
Time Indication: 0
Date: 2013.12.15
Time: 11:18:12
Freeze Frame:
Fault Priority: 3
Fault Frequency: 34
Reset counter: 149
Mileage: 217150 km
Time Indication: 0
Date: 2003.02.27
Time: 00:01:21
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 185
Mileage: 217352 km
Time Indication: 0
Date: 2015.03.13
Time: 12:22:05
Freeze Frame:
Fault Priority: 4
Fault Frequency: 1
Reset counter: 255
Mileage: 207105 km
Time Indication: 0
Date: 2003.03.10
Time: 07:48:14
Coding: 4063342
Coding: 0233408
1 Fault Found:
Freeze Frame:
Fault Priority: 0
Fault Frequency: 2
Reset counter: 189
Mileage: 217084 km
Time Indication: 0
Date: 2015.02.24
Time: 21:07:00
Coding: 0026918
Coding: 0004313
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 37
Reset counter: 189
Mileage: 215917 km
Time Indication: 0
Date: 2015.01.08
Time: 18:47:43
Coding: 0000027
Coding: 0010111
Coding: 0026918
Revision: AV1C1010
Coding: 0000331
2 Faults Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
Freeze Frame:
Fault Priority: 3
Fault Frequency: 8
Reset counter: 187
Mileage: 217296 km
Time Indication: 0
Date: 2015.03.12
Time: 13:37:48
Freeze Frame:
Voltage: 12.94 V
Count: 236
Coding: 0000002
Coding: 0000001
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 02:45:20
Coding: 0001003
Coding: 0026918
Coding: 0026918
Coding: 0101008
Coding: 0000004
LOG 2
Coding: 0011773
1 Fault Found:
Coding: 0000001
Coding: 0008597
2 Faults Found:
014 - Defective
000 - -
Coding: 0411648
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 189
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 22:30:10
Coding: 4063328
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Coding: 0020529
3 Faults Found:
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:07
Freeze Frame:
Temperature: 13.0*C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Freeze Frame:
Voltage: 11.10 V
014 - Defective
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Coding: 0111001
Coding: 00000030
Shop #: WSC 02311
Coding: 0021154
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 3
Reset counter: 149
Mileage: 217860 km
Time Indication: 0
Date: 2003.02.27
Time: 22:15:00
Freeze Frame:
Temperature: 21.0*C
Voltage: 10.75 V
Bin. Bits: 00000000
Coding: 0431707
1 Fault Found:
Coding: 0112151
Coding: 0001403
Coding: 0411648
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 3
Reset counter: 149
Mileage: 217856 km
Time Indication: 0
Date: 2003.02.27
Time: 22:30:10
Coding: 0000000
1 Fault Found:
Coding: 0015500
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:24:36
Coding: 4063342
Coding: 0233408
Coding: 0026918
Coding: 0004313
Coding: 0000027
Coding: 0010111
Coding: 0026918
Revision: AV1C1010
Coding: 0000331
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
Coding: 0000002
Coding: 0000001
Coding: 0001003
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:31:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:29
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:49
Coding: 0026918
Coding: 0026918
Coding: 0101008
Coding: 0000004
