Starter about to die? or just more technogremlins?
#11
Address 01: Engine Labels: None
Part No SW: 4E0 910 560 H HW: 4E0 907 560
Component: 3.7L V8/5V A 0010
Revision: 00000000 Serial number: AUX3Z0C2311792
Coding: 0011773
Shop #: WSC 02313 785 00200
VCID: 2643499791D20C1134C-8073
1 Fault Found:
19510 - Starter Will Not Turn Check the starter
P3054 - 001 - Jammed or Electrical Malfunction
Readiness: 0110 1101
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 A
Component: ESP 5.7 allrad H29 0400
Coding: 0008597
Shop #: WSC 02313 000 00000
VCID: 21495A8BF8FCEB2941E-8074
2 Faults Found:
00003 - Control Module
014 - Defective Replace the module
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
000 - - Check the connection than replace it
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 A HW: 4E0 035 729 A
Component: Interfacebox H43 0290
Revision: 00000000 Serial number: 300C7037517330
Coding: 0000000
Shop #: WSC 00000 000 00000
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 318LW027503658
Subsystem 3 - Serial number: ˇˇ20.12.02ˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇˇ
Subsystem 4 - Serial number: ˇˇˇˇˇˇˇ
2 Faults Found:
02084 - Component Protection Dealer has to remove CP
005 - No or Incorrect Basic Setting / Adaptation - Intermittent
Freeze Frame:
Fault Status: 00100101
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
01042 - Control Module; Not Coded VCDS code it
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 A
Component: KLIMAAUTOMAT 015 0240
Revision: 00000014 Serial number: 00000000013264
Coding: 0020529
Shop #: WSC 02311 785 00200
VCID: 5ABB2D67952A78F1404-800F
3 Faults Found:
01592 - Air Quality Sensor (G238)
014 - Defective Check the connection and/or replace it
Freeze Frame:
Fault Status: 01101110
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:07
Freeze Frame:
Temperature: 13.0*C
00066 - Rear Right Footwell Heater (Z43)
012 - Electrical Fault in Circuit Just live with it
Freeze Frame:
Fault Status: 01101100
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Freeze Frame:
Voltage: 11.10 V
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 HW: 4E0 959 655
Component: Airbag 8.4E+ H08 0840
Coding: 0431707
VCID: 63C51083A260B939132-8036
1 Fault Found:
01218 - Side Airbag Igniter; Passenger Side (N200) Treat yellow harness with DeoxIT
001 - Upper Limit Exceeded - MIL ON
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 A HW: 4E0 907 801
Component: EPB AV1C1010 H01 1010
Revision: AV1C1010
Coding: 0000331
Shop #: WSC 76873 873 66865
VCID: 1D31667BC484CFC9656-8048
1 Fault Found:
02596 - Rear Brake Pads Worn Replace
008 - Implausible Signal
Freeze Frame:
Fault Status: 01111000
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000003960
VCID: 5DB1267B84048FC9256-8008
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 2803311791
Coding: 303030393135313035414B56413032383033333131373931
Shop #: WSC 00031 210 91012
4 Faults Found:
02276 - Quiescent Current Stage 5 Just recharge for now
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:31:05
02272 - Quiescent Current Stage 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:19
02273 - Quiescent Current Stage 2
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:29
02274 - Quiescent Current Stage 3
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:49
Coding: 0011773
1 Fault Found:
Coding: 0008597
2 Faults Found:
Coding: 0000000
2 Faults Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Time Indication: 1
Coding: 0020529
3 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:07
Freeze Frame:
Temperature: 13.0*C
Freeze Frame:
Fault Priority: 3
Fault Frequency: 3
Reset counter: 149
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:14:09
Freeze Frame:
Voltage: 11.10 V
Coding: 0431707
1 Fault Found:
Revision: AV1C1010
Coding: 0000331
1 Fault Found:
Freeze Frame:
Fault Priority: 6
Fault Frequency: 1
Reset counter: 236
Mileage: 207088 km
Time Indication: 0
Date: 2003.02.27
Time: 00:00:39
Freeze Frame:
Voltage: 12.84 V
Count: 61
4 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 3
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:31:05
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:19
Freeze Frame:
Fault Priority: 7
Fault Frequency: 2
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:29
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 217862 km
Time Indication: 0
Date: 2003.02.27
Time: 22:32:49
#12
Thanks Mishar.
Is there anything there , other than the starter jammed code, that you think might have a bearing on no start symptoms?
Ive got a feeling the starter has failed.
many thanks
many thanks
#16
Thanks Mishar. I appreciate it all. It's gone to my indie for "standard automotive diagnosive techniques" I.e a piece of wire and a bulb. See if that starter is getting juice. Many thanks again. J
#17
#19
Check here. Shows the part, not sure if the diagram works for telling you where to find it since it's for the European model.
https://www.audiworld.com/forums/a8-...2877893/page3/
