Starting issue / Level Control Issues
Please take a look at the below VagCom results. In the mornings I go to try to start my vehicle and it will not even crank over. I have to cycle the key over and over and eventually it will start up without issue. I am almost positive this is from the brake light switch issue based on the ross tech wiki. I am also occasionally getting the ABS / Traction Control / Parking brake lights. It also seems I have to depress the brake pedal quite a ways before the brake lights engage.
I also have some issues with the suspension controls. It doesn't seem to be a leak... but it seems like it gets confused and doesn't know where it is in height. The green light will come on occasionally and indicate that the car ride height is low... but it is actually still in the standard position. Also... recently the compressor is getting pretty noisy.... it has been very very cold here also... wondering if that could be part of it.
Any thoughts are appreciated.
Sunday,22,February,2015,19:38:59:23698
VCDS -- Windows Based VAG/VAS Emulator
VCDS Version: 14.10.1.1 (x64)
Data version: 20150130
VIN: WAUML44E54N008090 License Plate:
Mileage: 222670km-138360mi Repair Order:
Chassis Type: 4E (4E0)
Scan: 01 02 03 05 06 07 08 09 0E 15 16 17 19 25 34 36 37 38 42 46
47 4F 52 53 55 56 61 62 65 72 75 76
VIN: WAUML44E54N008090 Mileage: 222670km-138360miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: Malfunction 0010
05-Acc/Start Auth. -- Status: Malfunction 0010
06-Seat Mem. Pass -- Status: OK 0000
07-Control Head -- Status: Malfunction 0010
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: OK 0000
0E-Media Player 1 -- Status: OK 0000
15-Airbags -- Status: OK 0000
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: Malfunction 0010
34-Level Control -- Status: Malfunction 0010
36-Seat Mem. Drvr -- Status: OK 0000
37-Navigation -- Status: OK 0000
38-Roof Electronics -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
46-Central Conv. -- Status: OK 0000
47-Sound System -- Status: OK 0000
4F-Centr. Electr. II -- Status: OK 0000
52-Door Elect, Pass. -- Status: OK 0000
53-Parking Brake -- Status: Malfunction 0010
55-Headlight Range -- Status: OK 0000
56-Radio -- Status: Malfunction 0010
61-Battery Regul. -- Status: Malfunction 0010
62-Door, Rear Left -- Status: OK 0000
65-Tire Pressure -- Status: Malfunction 0010
72-Door, Rear Right -- Status: OK 0000
75-Telematics -- Status: Malfunction 0010
76-Park Assist -- Status: OK 0000
Address 01: Engine Labels: 077-910-560-BFM.lbl
Part No SW: 4E0 910 560 A HW: 4E0 907 560
Component: 4.2L V8/5V G 0070
Revision: 00000000 Serial number: AUX3Z0C7521051
Coding: 0007773
Shop #: WSC 02313 785 00200
VCID: 1F4DDB7FCEE14ED977A-804A
2 Faults Found:
19510 - Starter Will Not Turn
P3054 - 001 - Jammed or Electrical Malfunction - Intermittent
17983 - Right Engine Mount Solenoid Valve (N145)
P1575 - 001 - Short to Plus
Readiness: 0000 1100
Address 02: Auto Trans Labels: 09E-927-156.lbl
Part No SW: 4E0 910 156 E HW: 09E 927 156 A
Component: AG6 09E 4,2l5V USA 0070
Revision: 00000001 Serial number: 0018802
Coding: 0000002
VCID: 2447D493E7876D012A8-8071
No fault code found.
Address 03: ABS Brakes Labels: 4E0-910-517.lbl
Part No SW: 4E0 910 517 A HW: 4E0 614 517 E
Component: ESP 5.7 allrad H29 0420
Coding: 0007597
Shop #: WSC 08221 000 00000
VCID: 2149DD87F895782941E-8074
1 Fault Found:
00526 - Brake Light Switch (F)
008 - Implausible Signal - Intermittent
Address 05: Acc/Start Auth. Labels: 4E0-910-131.lbl
Part No SW: 4E0 910 131 HW: 4E0 909 131 A
Component: FBS AUDID3 H03 0120
Revision: 01203603 Serial number: AUX3Z0C7521051
Coding: 0263168
Shop #: WSC 02311 785 00200
VCID: 58BFB063EB4FF9E1760-800D
Subsystem 1 - Part No: XXXXXXXXXXX
Component: ELV XXXX
1 Fault Found:
00230 - Transmission Park Selector Switch (F305)
010 - Open or Short to Plus - Intermittent
Freeze Frame:
Fault Status: 00101010
Fault Priority: 3
Fault Frequency: 0
Reset counter: 233
Mileage: 222672 km
Time Indication: 0
Date: 2015.02.22
Time: 15:09:46
Address 06: Seat Mem. Pass Labels: None
Part No SW: 4E0 910 760 C HW: 4E0 959 760
Component: Sitzmemory BFS H06 0060
Revision: 00000000 Serial number: 5DS 008 795-03
Coding: 3940448
Shop #: WSC 00000 785 00200
VCID: 2345D78FE2896A39532-8076
Address 07: Control Head Labels: 4E0-910-7xx-07.lbl
Part No SW: 4E0 910 729 J HW: 4E0 035 729
Component: Interfacebox H43 0600
Revision: 00000000 Serial number: 346HR037505257
Coding: 0000103
Shop #: WSC 08174 444 00569
VCID: 2F6D2BBFBE41DE59C7A-807A
Subsystem 1 - Part No: 4E0 910 609
Component: Bedienteil MMI H41 0010
Subsystem 2 - Serial number: 3
Subsystem 3 - Serial number: ÿÿ01.08.03ÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿÿ
Subsystem 4 - Serial number: ÿÿÿÿÿÿÿ
1 Fault Found:
01310 - Level Control System Control Module (J197)
004 - No Signal/Communication - Intermittent
Freeze Frame:
Fault Status: 00100100
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 222490 km
Time Indication: 0
Date: 2015.02.17
Time: 19:39:13
Address 08: Auto HVAC Labels: None
Part No SW: 4E0 910 043 HW: 4E0 820 043 B
Component: KLIMAAUTOMAT 015 0240
Revision: 065A0000 Serial number: 898053000
Coding: 1085761
VCID: 5ABBAA6B9543EBF1404-800F
Subsystem 1 - Part No: 4E0 910 772
Component: Sitzluefter FS H05 010
Subsystem 2 - Part No: 4E0 910 772
Component: Sitzluefter BFS H05 010
Subsystem 3 - Serial number: 898053000
Subsystem 4 - Serial number: HO08082003065A000000000027ÿ
Subsystem 5 - Serial number: 000027ÿ
Address 09: Cent. Elect. Labels: 4E0-910-279.lbl
Part No SW: 4E0 910 279 E HW: 4E0 907 279 E
Component: ILM Fahrer H11 0100
Coding: 0111113
VCID: 2A5B3AAB85A3BB71104-807F
Subsystem 1 - Part No: 4E1 910 113
Component: Wischer WWS D3 H30 0320
Coding: 00000030
Shop #: WSC 02311
Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
Part No SW: 4E0 910 111 C HW: 4E0 035 111
Component: CD-Changer H43 0340
Revision: 00000501 Serial number: AUZ5ZBC1020181
Shop #: WSC 00000 000 00000
VCID: 1939F567D0C520E989E-804C
Address 15: Airbags Labels: 4E0-910-655-84.lbl
Part No SW: 4E0 910 655 A HW: 4E0 959 655 A
Component: Airbag 8.4E+ H09 0920
Coding: 0530707
Address 16: Steering wheel Labels: 4E0-910-549.lbl
Part No SW: 4E0 910 549 HW: 4E0 953 549 A
Component: Lenksäulenmodul H09 0030
Coding: 0012241
VCID: 65C18997AC3D5409FD6-8030
Component: Lenkradmodul H02 0050
Address 17: Instruments Labels: 4E0-910-xxx-17.lbl
Part No SW: 4E0 910 900 HW: 4E0 920 950 B
Component: KOMBIINSTR. VDO H42 0070
Revision: D08 Serial number: AUDID3C7002892
Coding: 0000223
Shop #: WSC 03327 444 105121
VCID: 5CB7AC739F7715C1528-8009
Address 19: CAN Gateway Labels: 4E0-910-468.lbl
Part No SW: 4E0 910 468 A HW: 4E0 907 468 C
Component: Gateway H07 0040
Revision: 07 Serial number: 02005037090617
Coding: FCFE7BDD1B2304
Shop #: WSC 08252 444 83511
VCID: 2643CE9B91BB9F1134C-8073
Address 25: Immobilizer Labels: 4E0-910-131.lbl
Coding: 0263168
Component: ELV XXXX
XXXXXXXXXXX ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 233
Mileage: 222672 km
Time Indication: 0
Date: 2015.02.22
Time: 15:09:46
Address 34: Level Control Labels: 4E0-910-553.lbl
Part No SW: 4E0 910 553 E HW: 4E0 907 553 E
Component: LUFTFDR.-CDC H05 4290
Coding: 0015510
VCID: 2541C997ECBD94093D6-8070
2 Faults Found:
01772 - Signal from Level Control Pressure Sensor (G291)
Freeze Frame:
Fault Status: 00101000
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 222665 km
Time Indication: 0
Date: 2015.02.22
Time: 14:55:24
01400 - Suspension Level Control
002 - Lower Limit Exceeded - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 222679 km
Time Indication: 0
Date: 2015.02.22
Time: 19:22:28
Address 36: Seat Mem. Drvr Labels: None
Component: Sitzmemory FS H06 0060
Coding: 4071522
Address 37: Navigation Labels: 4E0-910-88x-37.lbl
Part No SW: 4E0 910 887 K HW: 4E0 919 887 C
Component: MNS US H41 0570
Revision: 00000000 Serial number: 355GT037506448
VCID: 356119D75C1DE4898D6-8060
Address 38: Roof Electronics Labels: 4E0-910-135.lbl
Part No SW: 4E0 910 135 A HW: 4E0 907 135
Component: Dachknoten D3 H01 0080
Serial number: 00000319500120
Coding: 0003989
VCID: 1D31E177C4ED5CC9656-8048
Address 42: Door Elect, Driver Labels: 4E1-910-802-42.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 801
Component: Türsteuer.FS BRM005 0100
Coding: 0028196
VCID: 5EB3A67B896B07D13CC-800B
Address 46: Central Conv. Labels: 4E0-910-289.lbl
Part No SW: 4E0 910 289 A HW: 4E0 907 289
Component: Komfortgeraet H03 0030
Revision: 00300003 Serial number: W040307310034
Coding: 0065086
VCID: 275DC39F96B186190FA-8072
Subsystem 1 - Part No: 4E0 910 853
Component: Heckdeckel H06 0050
Subsystem 2 - Part No: 4E0 907 719
Component: Neigungssensor H02 0020
Address 47: Sound System Labels: 4E0-910-223.lbl
Part No SW: 4E0 910 223 H HW: 4E0 035 223 B
Component: DSP-High D3/AUX H13 0370
Revision: Dev_D01 Serial number: 00000000246043
Coding: 0000016
VCID: 224BD28BFD936331584-8077
Address 4F: Centr. Electr. II Labels: None
Part No SW: 4E0 910 280 HW: 4E0 907 280 A
Component: ILM Beifahrer H07 0070
Revision: Serial number: 00000000020524
Coding: 0010111
VCID: 5DB1A177846D1CC9256-8008
Subsystem 1 - Part No: 4E0 910 511 A
Component: UGDO HL US H02 0030
Subsystem 2 - Serial number: VK4978T05LGE
Address 52: Door Elect, Pass. Labels: 4E1-910-802-52.lbl
Part No SW: 4E1 910 802 HW: 4E1 959 802
Component: Türsteuer.BF BRM005 0100
Coding: 0028196
Address 53: Parking Brake Labels: 4E0-910-801.clb
Part No SW: 4E0 910 801 C HW: 4E0 907 801 A
Component: EPB A32C0220 H02 0220
Revision: A32C0220
Coding: 0000532
Shop #: WSC 08221 444 83902
2 Faults Found:
01316 - ABS Control Module
013 - Check DTC Memory - Intermittent
Freeze Frame:
Fault Status: 00101101
Fault Priority: 3
Fault Frequency: 4
Reset counter: 233
Mileage: 222656 km
Time Indication: 0
Date: 2015.02.22
Time: 14:42:20
Freeze Frame:
Voltage: 13.56 V
Count: 236
02433 - Supply Voltage for Right Parking Brake Motor (V283)
011 - Open Circuit - Intermittent
Freeze Frame:
Fault Status: 00111011
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 222656 km
Time Indication: 0
Date: 2015.02.22
Time: 14:37:42
Freeze Frame:
Voltage: 12.42 V
Count: 93
Address 55: Headlight Range Labels: 4E0-910-357.lbl
Part No SW: 4E0 910 357 HW: 4E0 907 357
Component: Pre-AFS H01 0030
Coding: 0000001
VCID: 62CB928BBD132331184-8037
Address 56: Radio Labels: 4E0-910-541.lbl
Part No SW: 4E0 910 541 C HW: 4E0 035 541
Component: TUNER EU/US/RDW H41 0290
Revision: 00000000 Serial number: 304HU037539952
Coding: 0000002
VCID: 204FD883F39F71214E0-8075
1 Fault Found:
00858 - Connection; Radio Intermediate Frequency (IF) Output to Antenna Amplifier
011 - Open Circuit
Freeze Frame:
Fault Status: 01101011
Fault Priority: 5
Fault Frequency: 241
Reset counter: 184
Mileage: 183009 km
Time Indication: 0
Date: 2013.01.28
Time: 16:07:47
Address 61: Battery Regul. Labels: 4E0-910-181.lbl
Part No SW: 4E0 910 181 HW: 4E0 915 181
Component: ENERGIEMANAGER H02 0160
Revision: 00000000 Serial number: 00000000013334
Subsystem 1 - Part No: 000 915 105 AK
Component: von VA0 1308120335
Coding: 303030393135313035414B56413031333038313230333335
Shop #: WSC 12345 128 00289
1 Fault Found:
00992 - Consumption Cut-Off Active
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 222660 km
Time Indication: 0
Date: 2015.02.22
Time: 14:33:46
Address 62: Door, Rear Left Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 801 A
Component: Türsteuer.HL BRM004 0090
Coding: 0028196
Address 65: Tire Pressure Labels: 4E0-910-273.lbl
Part No SW: 4E0 910 273 HW: 4E0 907 273
Component: Reifendruck 2 H01 0210
Coding: 0212127
VCID: 5FCD9B7F8E610ED937A-800A
2 Faults Found:
01477 - System Switched Off
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 4
Fault Frequency: 253
Reset counter: 193
Mileage: 222351 km
Time Indication: 0
Date: 2015.02.17
Time: 08:10:34
Freeze Frame:
Speed: 0.0 km/h
Temperature: -10.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
01521 - Sensor for Tire Pressure
004 - No Signal/Communication - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 222359 km
Time Indication: 0
Date: 2015.02.17
Time: 08:32:28
Freeze Frame:
Speed: 74.0 km/h
Temperature: -11.0*C
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Address 72: Door, Rear Right Labels: 4E0-910-802.lbl
Part No SW: 4E0 910 802 HW: 4E0 959 802 A
Component: Türsteuer.HR BRM004 0090
Coding: 0028196
Address 75: Telematics Labels: None
Part No SW: 4E0 910 616 HW: 4E0 035 616
Component: Telematik USA1 0050
Revision: 00000002 Serial number: 0000ATD3003548
Coding: 0000005
Shop #: WSC 08174 444 01059
VCID: 60CF9883B01F31210E0-5122
1 Fault Found:
01531 - Emergency Battery
002 - Lower Limit Exceeded - MIL ON
Address 76: Park Assist Labels: 4E0-910-283.lbl
Part No SW: 4E0 910 283 HW: 4E0 919 283 A
Component: Parkhilfe 8-Kan H07 0030
Coding: 0001208
VCID: 60CF9883B31F31210E0-8035
End-------------------------(Elapsed Time: 04:11)--------------------------
Coding: 0007773
2 Faults Found:
Coding: 0000002
Coding: 0007597
1 Fault Found:
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 233
Mileage: 222672 km
Time Indication: 0
Date: 2015.02.22
Time: 15:09:46
Coding: 3940448
Coding: 0000103
1 Fault Found:
Freeze Frame:
Fault Priority: 5
Fault Frequency: 1
Reset counter: 230
Mileage: 222490 km
Time Indication: 0
Date: 2015.02.17
Time: 19:39:13
Coding: 1085761
Coding: 0111113
Coding: 00000030
Shop #: WSC 02311
Coding: 0530707
Coding: 0012241
Coding: 0000223
Coding: 0263168
Component: ELV XXXX
1 Fault Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 0
Reset counter: 233
Mileage: 222672 km
Time Indication: 0
Date: 2015.02.22
Time: 15:09:46
Coding: 0015510
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 233
Mileage: 222665 km
Time Indication: 0
Date: 2015.02.22
Time: 14:55:24
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 233
Mileage: 222679 km
Time Indication: 0
Date: 2015.02.22
Time: 19:22:28
Coding: 4071522
Coding: 0003989
Coding: 0028196
Coding: 0065086
Coding: 0000016
Coding: 0010111
Coding: 0028196
Revision: A32C0220
Coding: 0000532
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 4
Reset counter: 233
Mileage: 222656 km
Time Indication: 0
Date: 2015.02.22
Time: 14:42:20
Freeze Frame:
Voltage: 13.56 V
Count: 236
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 232
Mileage: 222656 km
Time Indication: 0
Date: 2015.02.22
Time: 14:37:42
Freeze Frame:
Voltage: 12.42 V
Count: 93
Coding: 0000001
Coding: 0000002
1 Fault Found:
011 - Open Circuit
Freeze Frame:
Fault Priority: 5
Reset counter: 184
Mileage: 183009 km
Time Indication: 0
Date: 2013.01.28
Time: 16:07:47
1 Fault Found:
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 255
Mileage: 222660 km
Time Indication: 0
Date: 2015.02.22
Time: 14:33:46
Coding: 0028196
Coding: 0212127
2 Faults Found:
000 - -
Freeze Frame:
Fault Priority: 4
Reset counter: 193
Mileage: 222351 km
Time Indication: 0
Date: 2015.02.17
Time: 08:10:34
Freeze Frame:
Speed: 0.0 km/h
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Freeze Frame:
Fault Priority: 3
Fault Frequency: 1
Reset counter: 189
Mileage: 222359 km
Time Indication: 0
Date: 2015.02.17
Time: 08:32:28
Freeze Frame:
Speed: 74.0 km/h
Error Code: 0
Not Recogn.
Not Recogn.
Not Recogn.
Not Recogn.
Coding: 0028196
Coding: 0000005
1 Fault Found:
Coding: 0001208
Calgary
08-06-2002 08:50 AM
