Suggested maintenance on my 08 A8L
My beloved D3 has 87k miles on the clock and we are moving to FL from NY this year.
Owned it since 18k miles and it is now paid off.
I want to address some of the maintenance items before it makes the drive.
Front end has all been replaced, A/C compressor, one headlight assembly and a bunch of other minor items all covered under warranty.
I know the air suspension will fail at some point plus a few other expensive items.
For what the car is worth I just can't justify replacing it with anything that would come close to the driving experience.
I've done recent brake fluid & fuel filter.
Plan to do the following soon, but what have I missed?
Trans fluid & filter
Power steering fluid
Anti Freeze
Serptentine Belt
Air filter
Diff fluid if suggested I'll do it
TIA
Anti Freeze
Serptentine Belt
Air filter
TIA
You're a wise man.
Change out all fluids on your car.
Use all the correct, approved fluids.
1st priority is the transfer filter & fluid.
the diff fluids need to be changed out by now, especially the middle one.
Have the brakes been flushed out & bled? If not, they're next.
After the fluids, change all the filters on your car.
Just doing all the filters & fluids will help your car last very significantly!
Good move to do all this!
Check your 4 sunroof drains and make sure they all drain easily out the wheel wells. Check the cowl drains too. If any of them seem to drain slowly or not at all, they need a cleaning.
Anti Freeze
Serptentine Belt
Air filter
TIA
Anti Freeze
Serptentine Belt
Air filter
TIA
Thank you everyone.
Brake fluid flushed and brakes bled within the last 500 miles.
I've always done all my own old school maintenance for the last 35 years.
So filters and fluids are always done.
I tried to get the dealer to do the trans fluid and filter under the extended service contract since it wasn't as silky smooth as before....they didn't go for it.
I planned to do Redline for the trans and oem filter. Isn't that what the long time D3ers use?
What have others used in the diffs? OR should I stick with OEM?
Forgot about the sunroof and cowling drains!
Before I take any long trip, if my car has been running well, I would only check the fluid levels and top them up. It would be ashamed to have someone open up the car and do things to it and by chance screw it up somehow and the car became walking wounded... The trip suddenly be gone or delayed?
Cheers,
Louis
Cheers,
Louis
There is only one fluid for the Torsen center differential. A liter is expensive, should flush several of them. It does not hold much.
The rear and front an be filled with other fluids, but going back with Audi fluid is a peace of mind decision.
I flushed my rear differential with Mobil One lube and a rear wheel bearing started to make noise soon after. Flushed differentail three times thinking it was the Mobil One. Finally replaced the wheel bearing and all is quiet now. I was half convinced the Mobil One damaged the differential. Never again for me.
I have to recommend going with ZF Lifeguard for the tranny fluid. The Mercon SP may be just as good. I have a 6 speed ZF in another car that was filled with Pentosin fluid and it works perfectly in Texas. Viscosity is higher than ZF.
thall6594
06-28-2013 06:55 PM
1999A8short
12-05-2007 04:46 AM
PaulW
06-09-2004 01:49 PM
