Suspension continued...
After replacing battery, all codes went away except the air suspension. It works ok for a minute, then goes to limp mode and goes straight to "lift". From what I have read, it could be the compressor and relay. I'm checking the fuse next.
Are there measuring blocks to check the compressor holding pressure?
Is there an easy way to soap up the struts and look for leaks?
Thanks again.
Thanks again.
You will hear any leaks if the car is in a closed garage. Usual failure mode of the WABCO compressor is one of the electric compressor motor magnets breaks free from the inside of the motor housing causing drag (poor output, so the electric motor stays running since air is being called for) which causes an overcurrent CONdition that eventually blows the fuse. Replacment fuse lasts for a couple of minutes and blows as well. You need to repair the compressor motor or replace the compressor.
Many others have experienced a relay failure. I have not so I can't offer any advice there.
Updates on suspension troubleshooting
Update to symptoms:
Yesterday drove down the street to the auto parts store and back. Suspension warning light never came on. Went to Walmart today, light came on after 2 miles. On the way back (4 miles), light never came on. If the fuse was blown, I would think the light would come on right away. If there is a slow leak somewhere, or the tank isn't holding pressure, mate this would explain. Could be relay going bad too.
I was digging around today looking for that pescy 40a fuse and relay for the suspension system and it where I thought it would be in the passenger side footwell under the carpet was the cruise control unit and no fuse.
Next place to look is under the steering wheel behind the dash. Anyone know how to remove safely? It's a 2007. I'm still looking for a way to use VAG com to detect location of problem and/or capability of compressor.
Its always interesting to see what you find when you are digging around. I'm missing a couple Of screws under the dash where the airbag is, leave it up to the dealer too to say "they'll never notice these are missing". Interior is in impeccable shape except for the broken armrest button, rear ashtray, and rear cup holder, all easy to fix.
Yes, I have Ross Tech. I'm so used to the D2, not really sure where to start....
SteveNZ
Q7 MK 1 Discussion
08-15-2018 02:18 AM
MP4.2+6.0
37
10-31-2017 06:15 PM
bacdoc
04-20-2012 02:31 PM
AudiDreamr
08-05-2005 07:46 AM
