When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hello, i had the same problem missing seuspension setup on A6 4F. I was able to get it back tahnks to this forum. But most of the possitions are still grayed. Diagnostic shows 0 errors in the suspension unit. Any idea what can cause the problem? If i try to move up and down via vcds it works so it seems to me that still is something uncorrect in the mmi.
Some components are faulty. Adaptive suspension only shows up when everything is working, not sure what you did with VCDS. If the system sensed the struts leak or valve block is faulty then it won't show up. It seems you used VCDS to turn on Lift mode and got stuck there. People who use VCDS tend to break the control system. When you're in lift mode, the pump doesn't work, hence self leveling system turned off. Get out of the lift mode then may be others will show up.
Thank you for feedback. I know the level is grayed in caso of faulty components but in this case there is error message in the diqnostic. I have 0 errors in level control unit. Thats what strange to me. Have no idea how to leave that lift mode.
