Telephone box / ecu location? Need help quickly...
I couln't get VCDS to read nr. 77 (Telephone) so I went to Audi service....
Gentlemen at the audi secvice told me that my telephone ecu was broken and they gave me that part number... It was 8E0 862 333 AX..
It was too expensive at their store (here in Finland) so I ordered it from ebay.
So now I have new part but I couldn't found that old one from my car.. Is here anyone who could get that location for me?
I thought that it would have located under passengers seat? There is some boxes but not that telephone box... Or do I have to look more precisely??
I didn't have time to look at weekend or today but I think I could check it out tomorrow... Thanks for your extremely fast answer.. That picture really shows that location very well...
So it is under the drivers side floorcarpet.. It should be quite easy to get chanced..
Now I finally had time to search that box... I found one module under that drivers side floor carpet... But it wasn't that 8E0 862 333 AX. There was 4F1 862 335. I took a photo from it: upper photos are from that box that I found and lower photos are from my new part... Just where it could be hiding?
The first two pictures are of the Bluetooth module under the drivers feet. Next two are of an old Nokia module that is useless. Gentlemen from Audi service gave you wrong part number.
So now I have one useless 700e unit and problem is still on.. I'll post my problem here if you guys might have some answers to me.
I have Audi mobile phone in my A8L and when I press that TEL-button in MMI that says "Telephone is not installed" and also I coudn't get VCDS to contact phone module ( I think it was nr 77 ). Serviceman said that he had checked all connections and groundings and all were fine... ---> module is broken...
So is my best option to buy that similar box I have in my car?
Banned
Do you have a bluetooth enabled smart phone, or any bluetooth phone to connect to your vehicle by way of bluetooth, NOT that old analog nokia phone, as I believe even in Finland you have done away with "analog" correct, therefore that nokia phone is dead.
Banned
Phone kit 4F1 862 335
This is a Telephone kit for Audi 2007
SW: 4F1 910 336 C after updating to 5150
Bluetooth phone 4E0 862 393 B
This is from Audi A8 L 2005.
It is MOTOROLA Bluetooth phone. This part does not contain any sim card or GSM. It works only within car range and displays what is in the car phone unit.
The phone contains one replaceable part (Battery).
The Battery is 3.5v and the part numbers are :
■Audi : 431 035 747
■MOTOROLA : SNN5705B
my info for my 2005 A8L W12 with "Bluetooth" see the bluetooth cradle under arm rest, do you have that phone cradle ?
you remove the nokia and that cradle will pick up any bluetooth enabled phone, unless your bluetooth module is dead and that is why #77 will not show up as you need a new one.
Address 77: Telephone Labels: 4E0-910-336.lbl
Part No SW: 4F0 910 336 H HW: 4E0 862 335
Component: Handyvorb2 H10 1130
Revision: 00000000 Serial number: 00000007522151
Coding: 0010900
■Audi : 431 035 747
Coding: 0010900
