When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hi all I was just wondering if there is an easy way to check the timing belt. I am planing to buy a 2006 Audi A8 fully loaded soon but it’s at 198000 km so want to check it to be sure. It starts and drives quietly but want to be 100% sure it’s good.
lol its an audi... nothing is easy...
with those miles... and you want peace of mind.
After buying it... do all the maintenance that you are unsure of.
It's easy to check. Pop off the cover on the driver's side, and see what the belt looks like. Unless it looks brand new, with texture (not shiny) and some kind of markings, plan to replace it and everything it touches.
Setting TDC
Need advice how to proceed. I think my last mechanic did not go a good job aligning washer type thing. I was originally confused how people found the TDC. Most of the posts removed the plastic cover before setting TDC. I had to to the plastic cover back to get TDC.
Set TDC
The next pix the left cam looks fine looks fine left cam
I believe the mechanic did not a good job when he tightened the the right cam bolt see pix it is off by a couple of mm
see his markings are off That thing is off by a couple of mm
To install that special crankshaft holder bolt remove what looks like an oil filler plug. 8mm allen wrench needed.
That special bolt went in easily without any resistance....
image of that locking bolt took the advice of my Bally and removed the cv joint splatter guard.
Both cam sprockets need to be loose/freewheeling with the crank lock and cam lock tools in place. The belt then needs to be positioned and the tensioner released. Then the sprockets should be tightened up, and the cam and crank lock tools removed. When you release the cam lock, the sprockets shouldn’t move relative to each other, otherwise you need to redo it.
