Timing Belt Service Kit?
#11
I am at 103k. I am planning on doing the belt change myself. I found out that their are different engine codes between 04-05 and 06's 04-05 have BFM and my 06 is a BGK. Does anyone know if the belt from a BFM kit can work on BGK engines. Blau said it would not work but, I don't know if they are saying that becuase it has not been tried or what. I know the BFM belts have 253 teeth but could not find a tooth count on belts for BGK. Also Mister Bally I would greatly appreciate any pointers you may have on replacing the belts. Once I start I will be replacing both belts, thermostat and water pump as well as pulleys and hydraulic tensioner. Thanks for any help you guys can provide.
#12
I thought the BGK engine has no timing belt, only a chain. Timing blt is at the front of the engine-large black covers are obvious at the front of each cylinder head-easily removed with two Torx head screws being removed and look for a belt. The timing chain engines have it at the back of the engine.
#13
#15
Has anyone priced these parts from Sunset Imports in Oregon? They sell OE at cost + 15% which for my 964RSA is cheaper than any of the aftermarket suppliers selling OEM. The difference might be important for any future CPO claims? I'm just starting to work on my A8 so I haven't looked, yet. If there are enough of us we should look into doing a tool rental/swap too?
#16
I did plan to buy the parts at a dealer and buy the tools for "next time". However, money is alot tighter than it was when I bought my overpriced sewing machine (a line from the movie Hollywood Knights refrencing several Porsche 356's).
#17
I just got my parts in the mail from blauparts. Ended up shipping in two days flat. My only question is I'm guessing this isn't the OEM thermostat. Anyone have any experience? Is this one a better quality one than the OEM one that you get from the dealer?
#19
Yes i saw that right after I posted lol. Thanks
Just want to make sure that the Blauparts thermostat is better than the OEM one. As I would hate to have all the blauparts installed and have the thermostat be a less reliable one than the OEM.
#20
Do not buy from blau parts.
I am on my 3rd water pump since I did the timing belt replacement.
Even the serpentine belt was bad.
When I sent the water pump back to them they said it's do to acidic coolant.....they sold me the coolant!!!!
STAY AWAY FROM BLAU PARTS. VERY CHEAP QUALITY.
