TPMS
I've always wondered that
You would think they would be dead on being that they are electronic.....but really wonder....all it takes is a reading with a hand held gage to determine.
I've found that they are fairly accurate. Temp difference?
I use a hand gauge when inflating the tires and afterwards the TPMS will be reading w/n a half a psi. You will notice the pressures change with temperatures. So Greenie is really losing any air in the cold, it's just shrinking ;-)
Check the pressures when cold, then see how much it changes after driving. The heat generated in the tires from driving will increase the tire pressure several psi (YMMV).
I have also found the TPMS to be quite accurate. In fact, I notice
that the variance in pressures is sensitive to extent that when the car is sitting, the temps on the wheels in the sun will be a little higher than for the wheels in the shade.
