TPMS question
I need to order 5 new replacement Beru units, I will get them from Tirerack along with stems to play it safe.
Can my local tire shop install, or do you need to have a special audi tool to vag these or calibrate.
I keep getting yellow malfunction and the sensors are 5+ years old.
Is it plug and play, or do they need a special vag tool to calibrate once re-installed?
on your car, select store tire pressures in MMI (maybe 05 is initialize wheels I think, mine is an 06) and within 20 miles of driving your pressures etc. should display. I just bought a winter wheel package with TPMS sensors installed. Once on the car, store tire pressures is set, the sensors are recognized within 20 miles or so.
Held in my a simple torx screw internally and the plastic nut you can see externally. Most all shops now have a basic understanding of them since they are required on most new all cars now.
geordie
9
12-13-2006 05:02 PM
