Sponsored by:
Sponsored by:
Troubled by A 8 Experiences
Old 09-19-2005, 04:34 AM
  #21
Paldi's Avatar
Phaeton buddy had A/C-heater fan stay on and drain battery.
Old 09-19-2005, 04:49 AM
  #22
AudiWorld Expert
no.radar's Avatar
Cars that leave you stranded (5x!!) are a MAJOR frustration for sure. (Esp. $60k+ cars.)
Old 09-19-2005, 05:01 AM
  #23
tozoM8's Avatar
Default It will take forever at the dealer.
Disconnect the negative battery cable, put a 12V test light between the cable and the battery's - post. It will light up. Now start to pull out the fuses one by one. When the light goes dim, you found your circuit, that drains your battery. It will take you 5-10 minutes. Of course you still have to deal with the problem, but you don't have to take any crap from the dealer. Usually they start to replace expensive parts without this simple test.
Good luck!
Old 09-19-2005, 05:59 AM
  #24
greenie's Avatar
The car is under warranty so the parts are on Audi.
Old 09-19-2005, 01:20 PM
  #25
New Member
NightBlue's Avatar
Default I've noticed my lights stay on...
If I leave my turn signal on and push the "off" button. Car turns off, I walk away and the fog lights are still on! They never turn off as expected with the lights set on Auto. I've done this several times now and it would probably drain the battery overnight (although I've never left it that long). I'm careful not to leave the turn signal on when I turn off the car now. Could this be the problem?
Old 09-19-2005, 02:02 PM
  #26
New Member
Blade04's Avatar
Default Re: I've noticed my lights stay on...
Thanks, great thought but alas, not the problem. The dealer put an energy management module on the battery to monitor for the source of drain. After a thorough analysis today, they came up empty handed. Though there is an update for the module that Audi has suggested be loaded.
The car is about to turn 40k mi. Given thhis continued issue and having to be flat bedded in on a regular basis, I'm going to ask my service manager to have Audi extend the warranty.
Old 09-19-2005, 04:51 PM
  #27
tozoM8's Avatar
Default I know, but you can save time and aggravation and you don't have to drive a.....
Kia rental car for weeks.
Old 09-20-2005, 07:03 PM
  #28
geordie's Avatar
Default Isn't that just the "coming home" function? ...
MMI - Car - Systems - Exterior Lighting
Audi0609
02-27-2019 11:20 AM
Craig283
54
06-26-2017 06:00 AM
gdaniel
02-12-2009 06:43 PM
Blade04
10
10-20-2003 01:54 PM
Quick Reply: Troubled by A 8 Experiences
