trunk latch issue
#12
I thought my trunk went into winter mode(Brozee words) and wouldnt close. I did a search and found this thread. I dont hear a motor when trying to latch the trunk. It will not lock at all and remains open. I am having the same problems as the OP.
In the attached pic, is that the spring that you are talking about Mishar?
Going for the lock next..
#13
Yes, that is the spring, but yours is OK. Try to clean and lubricate. It looks like that middle piece where latch should engage is a bit lower than it should be. Check the micro switch in there. I am not sure about this but there must be one.
#14
I cleaned it up with Brakleen and WD40. I used anti-seize lubricant and moved everything around, still will not lock. I pushed the lock all the way up but it never locks. I should it be that or should it lock when push in?
#16
Finally success!! Thanks JohnnyJ. I pulled the cover off(its just kind of pops off) and cleaned and lubricated it like I did the striker plate and it closed! The cover is still off right now. I will leave it off for today and put it back on tomorrow(Still at work and its getting a little cold outside.)
#17
I had the same issue and I lube the trunk latched and worked for a while. After the second time it would not work, I just replaced it and now works every time.
#18
My dear mother slammed the trunk lid closed this morning... Now Im having the same problem.. the upper latch on the trunk lid will not lock.
should I be able to move the internal part manually and have it latch??
qwerty
07-29-2002 07:26 AM
