Trunk Lock Replacement
#51
AudiWorld Wiseguy
Hi! Looks like im having some issue with my trunk as well. it was fine in the summer but right now as we speak it isnt as cold yet. but anyways, it wont lock even if i close it manually or with the button. so basically it does not latch at all and wont lock.
it looks like just replacing the lock mechanism as mentioned here with that part number you posted should fix this issue? just want to make sure!
I have a 2004 A8L.
Please let me know! Thanks
I have a 2004 A8L.
#52
Hy huys , im a newby here ,, need some advice , my audi a8 2004/5 3 0ltre tdi boot is not locking properly , audi advised to change the lock which i did made no difference , what happes is the motor brings the boot down but does not pull tight shut , the boot seems to lift back up out of position and is not locked correctly , shows up on the dash as open and my alarm security system then fails as the boot is reg opened ? do i need to change the motor which opens up but weakly closes on the button but then the problems start ?
#53
AudiWorld Wiseguy
The soft close mechanism has failed. Most likely a broken spring. See here on how to fix and let us know how you get on.
https://www.audiworld.com/forums/a8-...ishar-2866079/
#56
AudiWorld Wiseguy
I don't understand what you mean? Have you confirmed that when you manually latch the trunk latch, the strike pin mechanism is moving down or not? If not, have you been able to ascertain if the spring is still in place in that mechanism?
#57
yes Dave the lock pin goes down , when i press the button to close , the boot lid comes down starts to lock then the lid raises about a quarter of an inch , on the right hand side , then goes down but still registers as open ? and the alarm system will not function , the diagnostic test at audi said change boot lock , i did , still got the same problem ? however it has once or twice rectified itself only then to go back to not working correctly
#58
I wrote up a quick fix for the trunk lock issue that causes a lot of grief and is relatively easy and inexpensive to fix.
</head>
<body><b>
<p>Instructions for replacing your upper trunk latch.</p></b>
<p>This resolves issues with having to slam trunk to get it to latch and having the trunk close and then re-open when you press the close button. The trunk latch was known to be defective and has been re-designed. This same part is used on the A4,A5,A6, Jetta and Passat.</p>
Time required less than 1 hour. <font size="3" face="Calibri"></font></font><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image002.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image002.jpg" border="0" alt="Tools" width="93" height="129"></a>
<p>Required Tools:<br> Torx 25 driver <br>Phillips screwdriver<br>Small flat blade driver <br>Plastic pry tool/putty knife or other instrument<br>10mm socket driver (not pictured)
<p>1) Order part number 4F5 827 505 D </span><a href="http://www.audipartsnationwide.com/partlocator/index.cfm?action=getJointLocator&siteid=215503 &chapter=&sectionids=0,2822&groupid=51 935&subgroupid=3276&make=2&model=A8&am p;year=2005&catalogid=2&displayCatalogid=0 "><u><font color="#0000ff" size="3"><font color="#0000ff" size="3"><span lang="EN">Lock</u></font></font></span></a><font size="3"><span lang="EN"> from the online or from the dealer. Cost is about $45 online $68 from dealer</p></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image004.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image004.jpg" border="0" alt="Part" width="226" height="155"></a>
2) If you go to the dealer pick up an extra metal clip that is used on the trunk trim that you will be pulling off. They get lost very easily.
<p>3) Pry off cover of emergency release to get to Torx 25 screw on emergency release handle</p></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image006.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image006.jpg" border="0" alt="ERelease" width="263" height="154"></a>
<p></p>
<p></p>
<p>4) On the other side on the handle pull there is a small plastic door that when opened will reveal two Phillips screws that secure the
other handle lift to trunk. </p>
<p>Notice picture is taken from sitting inside the trunk.</p></dir></dir></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image008.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image008.jpg" border="0" alt="Pull" width="284" height="177"></a>
<dir>
<dir></font></font></span><font size="3"><span lang="EN">
<p>5) Take out tool kit – 4 Phillips with plastic covers, and pull off black plastic cover over trunk lock</p></dir></dir></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image010.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image010.jpg" border="0" alt="TrunkTool" height="186"></a>
<dir>
<p>6) Pry off back panel using plastic tool and pulling. Red indicated approximate position of clips</p></dir></dir></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image012.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image012.jpg" border="0" alt="Lid"></a>
<dir>
<p>7) Disconnect trunk light wire harness. Place trunk liner out of way.</p></dir></dir></font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image014.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image014.jpg" border="0" alt="deck"></a>
<dir>
8) Disconnect connector to trunk release and remove 2 – 10mm nuts, note position of emergency release and lock cables.Remove lock cable first (cable coming from right bottom in picture). Unbolt unit and then slide emergency release cable out.
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image016.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image016.jpg" border="0" alt="motor"></a>
<dir>
9) Remove and replace motor assemble, and replace BOTH cables the same order as you took them out. Remember to replace flat plastic cover over release cables. Test emergency release and key by license plate before replacing panel.</font></span><font size="3" face="Calibri"><font size="3" face="Calibri"><span lang="">
<a href="http://s1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/?action=view&current=image018.jpg" target="_blank"><img src="http://i1218.photobucket.com/albums/dd415/mbreitbart/Audi%20Trunk/image018.jpg" border="0" alt="NewPart"></a> </dir></dir></font></font></span><font size="3"><span lang="EN">
<p>10) Put back together and enjoy a working trunk lock!</p></font></span></font></font></font>
</body>
</head>
<body><b>
<p></p>
<p></p>
<dir>
<dir>
<dir>
<dir>
<dir>
</body>
cre8value
9
12-24-2022 04:50 AM
Matt@H2OTuning
11-26-2013 07:51 AM
boatrace
04-14-2007 06:22 PM
