When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
I did it once or twice as I swapped in and out the W12 fridge but couldn't describe specifics beyond I got in there and just tried to pull carefully to get inside frame trim out first.Once that comes off, there are a few fasteners that hold the assembly in. I remember trying to look and finding little documentation about it.
Here's how I did it...
On the inside of the car there's a plastic rectangular trim piece that snaps away from the pass thru. I believe there's 4 contact points, on each corner, that I was able to get my finger behind and release.
Once that's unsnapped, you can simply push the ski sack into the trunk. no tools needed.
seems like getting a fully functional beer door is going to be easier than i first suspected
thanks!
Yes, but REACHING it from the front is another matter entirely... impossible in an A8L.
I just returned some stuff to Sears and with my merchandise credit bought this cooler on clearance for $30... it appears to have just the right size door.
Doesn't exactly freeze (says it cools to 50 below ambient temp) but better than nothin'!
Awdinut is the one who knows all about trunk fridges...
-Tom
interesting.... i may have todo some serious looking into that one. im mostly concerned with how much heat it may put off with the compressor running, would something like that affect other things in the trunk? also, i had to drill out the rivets holding the hinge for the trunk side door, i can now gain access to the trunk from inside the cabin
also, its more of a "hide the beers" thing when your sitting in a park n ride with a few friends after a late night base jump from your favorite antenna and a cop pulls in... no way i could reach the back seat while driving, let alone into the trunk.
