ugh, have the ?jack? light on the dashboard. car MMI says it is not in jack mode though
also the headlight range thing came on. Ugh, just picked the car up yesterday afternoon. its an 05.
Re: ugh, have the ?jack? light on the dashboard. car MMI says it is not in jack mode though
I think you may be seeing the "suspension malfunction" yellow warning which uses the same "jack mode" warning light on the dash. Could be what I had last December, Blown 40 amp fuse that disabled the suspension. A real pain to get to. See my previous posting here about the ordeal as well as my picture poster showing why it took me an hour just to get to the silly fuse.
After the new fuse blew within a minute, it confirmed that the compressor motor was defective ($1500 for parts & labor to have dealer replace). VAG diagnostics will give you a good confirmation. Something like: "suspension power missing or short to ground".
You can also verify this without diagnostics if MMI shows you're not in jack mode AND when you go to suspension settings if all adjustable modes (normal, dynamic, lift etc.) are grayed out. Plus, car rides like crap. You'll want to avoid much driving over poor surfaces and a lot of weight in the car if there is no air in the suspension so you don't damage the air springs.
I drove mine on decent roads, 25 miles to the dealer after I replaced the fuse myself. No damage done to the suspension. At the time, I wasn't sure if it was the compressor although I had a feeling it was. I was pressed for time with the holiday season and all and I had a long trip coming up so I paid the dealer to replace it. Next time I'll do it myself.
I even have a spare compressor for the next time it fails!
Just the other day I posted a link to the engineering drawing of the air suspension (ECAS-Electronically Controlled Air Suspension) compressor assembly on the WABCO Automotive website. WABCO make the compressor for Continental-Teves who sells it along with their air springs to Audi.
so here are the codes. i cleared them and the jack thing came back on right away
and now the options are greyed out.Guess i will be ging to the dealer.
Address 34: Level Control
Control Module Part Number: 4E0 910 553 H
Component and/or Version: LUFTFDR.-CDC H06 4480
Software Coding: 0015510
Work Shop Code: WSC 02313
2 Faults Found:
00141 - Rear Body Acceleration Sensor (G343)
009 - Open or Short to Ground - Intermittent
Freeze Frame:
Fault Status: 00101001
Fault Priority: 3
Fault Frequency: 2
Reset counter: 187
Mileage: 48466 km
Time Indication: 0
Date: 2007.10.02
Time: 08:10:13
01437 - Control Position not Learned
005 - No or Incorrect Basic Setting / Adaptation
Freeze Frame:
Fault Status: 11100101
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 48580 km
Time Indication: 0
Date: 2007.10.06
2 Faults Found:
Freeze Frame:
Fault Priority: 3
Fault Frequency: 2
Reset counter: 187
Mileage: 48466 km
Time Indication: 0
Date: 2007.10.02
Time: 08:10:13
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 146
Mileage: 48580 km
Time Indication: 0
Date: 2007.10.06
sugaryling
Audi allroad
13
06-12-2008 10:35 PM
kona1skier
Audi allroad
01-29-2007 07:50 PM
