Urgent! Cant access MMI
Just connected new bluetooth module instead of onstar and XM radio. Started the car and MMI screen wont show anything. Also with vag-com can not access radio, navi, cntrl head, radio and smth else. MMI screen actually came out with start up screen, but then went black and wont go down
There is a break in the MOST ring.
Likely from the IN/OUT connections be reversed or not snugly inserted in the new module.
Firstly remove the new module and use a loopback connector to verify.
If that brings everything back to life use loop break diags in VCDS:
http://www.ross-tech.com/vcds/tour/optical-bus.html
Additional info http://www.mostnet.de/technology/int...ion/index.html
There is a 3-finger salute to restart MMI.
THis is I think the same on D3:
https://www.audiworld.com/forums/sho...52&postcount=4
![](http://www.trick77.com/wp-content/uploads/2009/07/audi_mmi.png)
ps - Glad it was just a swapped pin ! I've taken customer networks down doing that =0)
pps - Clear DTC's before you restart the MMI just in case
MMI wont restart and I still get code 00384 OPtical databus open circuit. Damn, I checked the ring, also bought from dealership a plug to go into MOST.
I wonder if thats because of ring break diagnostic wire which was connected to XM module. Its not connected to anything now, could that be the problem?
I am not sure but I think I had the same Optical Bus Diagnostic with broken Bluetooth module installed at the same place. I've connected Sirius back and everything was OK. Returned the thing and bought a new one and it worked flawlessly. Still does (knock, knock).
Check pins and everything again.
