Vag-Com Interface Problem
This afternoon I connected my Ross-Tech Hex-USB with laptop running the latest VCDS version into my A8 and found that it could only read the engine controller (# 01). For all other controlers VCDS signalled "No Response from Controller". I then tried to read the controllers on my Allroad and it worked fine.
Does anyone know if there is there some special lock or security mechanism on the A8 that need to be turned off?
Yup. I have both cars sitting side by side in the garage and it works with the Allroad just fine, but will only communicate with the engine controller on the A8.
Since CAN bus is a serial interface if the VAG-Com can talk to the one controller that rules out the cable as well as the PC and the software...
Bing-Go! That's probably it:
http://www.ross-tech.com/vcds/canbus.html
Luckily Ross-Tech has a trade-in / upgrade program!
Thanks for the help!
Just read the thread and right after the original post I said to myself; "you need the interface w/ Control Area Network CAN/J1939" for D3 A8's. Otherwise it may partially communicate.
My '01 Beetle works with the other interface but I just use the Hex+CAN for everything.
The A8 Doc
07-21-2007 12:06 PM
