VAG recoding after new battery
I know I've read about this here before but the search didn't find anything useful. I need to replace the OEM battery on my '06 SWB sport, actually surprised it has lasted this long!
I know there is some code that needs to be entered on the VAG-COM ( which I already use a lot) but wonder if there is a proper code on a group49 battery from NAPA or O'Reilly's??? I'm sure the dealer will want my left arm if I buy it there...
TIA
TIA
surprised you can't find my post...
hang on, I'll look.
K9
hang on, I'll look.
K9
TIA
TIA
https://www.audiworld.com/forums/sho...e#post24260705
you find most of what you need, including some battery codes you can use..
K9
K9
Figured I needed a new battery because after the car had sat for over a week the clock and date were wrong- thought it had shut stuff down to save charge as I didn't have a trickle charger on it.
But I've checked the battery level on MMI a few times when driving and it always says 100%. May wait until closer to winter and colder weather... just don't want to go out sometime and have it dead!!
...was that the MMI battery meter showed 100%, alright. But, it was only 100% of that particular charge, whatever the remaining battery lifespan was.
As the battery neared the end of its lifespan, the MMI still showed 100% when fully charged, but for shorter and shorter periods of time.
So, my battery that had 5-10% of its total lifespan remaining, showed 100% whenever it was completely charged. But that was only a complete charge on the 5-10% remaining.
Hope that makes sense.
Reality was that when she left me hanging after 15 minutes of radio use during a lunch break, and I had to call for a jump start (a painful story in, and of, itself...), the bugger got replaced immediately. I chose to go through the coding procedure with the VCDS even though some posts said it wasn't truly necessary.
Carry on...
Carry on...
...swap it out and recode.
K9
K9
Carry on...
Carry on...
ronnie-j
08-08-2019 03:33 PM
that_tg
14
11-11-2013 09:16 AM
Fcasadon
12
09-02-2005 08:31 PM
