Sponsored by:
Sponsored by:
VCDS Ride Height Adjustment
Old 09-01-2013, 03:16 PM
  #11
mishar's Avatar
Originally Posted by The Simps
My car has the sport suspension - will I still be starting with 0015510? or will it already be at 0011110?
Also, as far as measuring wheel centre to arch lip, I'm running +25mm od oversized wheels so do I need to take 12.5mm off my numbers before inputting into VCDS?
Looking to do it on a friends VCDS any day soon so want to be prepared.
Thanks.
Original coding for both suspensions is 0015510.
Center of your wheel is at the same distance from the arch no matter what wheels or tires you are running. That's why they use this measure. So no adding.
Old 09-01-2013, 03:29 PM
  #12
The Simps's Avatar
So could I leave my lowering links installed then seeing as they are on and giving it the correct measurements will give same effect as having std links on?
Old 09-01-2013, 03:37 PM
  #13
mishar's Avatar
You didn't mention lowering links before. How much is it lowered?
Old 09-01-2013, 04:02 PM
  #14
The Simps's Avatar
I didn't mention because I assumed I would need to refit the stock ones.
Just been out and measured and currently centre to arch lip is 350mm all round. So if stock is 416 & 398 and mine being a sport is 396 & 378, I'm assuming it means I'm lowered 46mm front and 28mm back?
Old 09-01-2013, 04:07 PM
  #15
The Simps's Avatar
So I need to input 0010010 then my recorded values should be 371 & 353? But to then match my current 350 & 350 ride height I need to trick it with inputs of 392 & 356?
Old 09-01-2013, 08:11 PM
  #16
mishar's Avatar
What height you would like to have at the end?
Rick123 (02-28-2024)
Old 09-02-2013, 12:30 AM
  #17
The Simps's Avatar
I would like to end up with what I have now - 350/350.
Old 09-02-2013, 07:43 AM
  #18
mishar's Avatar
I would suggest you to lift it to stock 396/378 before you start VCDS lowering, than lower it as much as you can (may be even to 350/350) and than adjust it with links.
Old 09-02-2013, 08:51 AM
  #19
The Simps's Avatar
Thanks for the advice Misha
Old 09-03-2013, 03:46 AM
  #20
1Wasserwerks's Avatar
Sounds like you want to attack pot holes and speed bumps. Make sure to send pics after you have it all dropped.
Quick Reply: VCDS Ride Height Adjustment
