water leaking inside car from engine bay
#22
So where are the A/B drains? Under the large cabin filter? I vacuumed out this area (as best as I could.. lots of brake lines and other things in the way), should I pour water there to see if it pools up, and then fish around for the drain holes?
With my A4, I could just lift the car up and poke my fingers in the bottom of the drains under the car.
#23
I bought a long power nozzle for my garden hose and blasted the area that was recommended in this thread. I then shop vacc'ed it out when it filled up with water. I did that twice and then the bird time the water started gushing out the bottom of the car. Thanks for all of the help! I had tried removing everything from the area, no go. Then I tried going from the bottom of the car with no luck. Finally this worked. I will do this every 6 mos now.
#24
What could go wrong if you remove those plenum drains?
They are just 2 rubber drains that causes a lot of problems. If you remove them, then its just 2 big holes for water and debris to "escape" quick and easy.
I also had clogged drains and needed to remove all carpets to dry them up. I went under the car, used a long metal stick with a small brush in the end and remove ALOT of debris. The drains are bended so on my car there where ALOT of debris inside and in those bends.
#26
i just went and did exactly this the other day. I used personal use home Depot string as well as commercial type. It bunched up and wouldn't go down the bend in the a pillar. We soon as it hit a turn it wouldn't go through.
#28
is there a write up or how to available.. tried feeling around for the plugs based on the diagram posted but cant feel anything. is there a specific spot i should be feeling around by the pollen filter? also are the plugs plastic or rubber knowing this will help me figure out what texture to feel for.
#29
Just cleaned my plenum drains from the bottom of the car with long screw driver that I got from harbor freight about 24" long. You can see them on two sides of the transmission. For sun roof drains I have used 1/4" tubing that I use for aquarium filtration.
#30
rince the tubes with a Polident solution of hot water along with your drill chucked up to whatever cable/wire/line turning slowly.
Nothing like minty fresh tubes.. pc
