What Additive Do You Use?
I've been using Lucus Oil Fuel Treatment, 8 ounces at fill ups to keep the fuel system clean and smooth. I buy the 1 gallon and keep it in the trunk for a regular additive to combat upper cylinder issues from ethanal and bad gas. It seems to be working good.
What about you? Fuel additive? Oil additive? Transmission, differentials?
Why? The Lucas stuff is snake oil btw, about the only fuel additive that will do anything will have to have PEA in it. Only 3m and chevron make ones with PEA.
None. I just use 5W-40 motor oil with the VW designation. Usually Total, Castrol or Valvoline.
Transmission and differentials still have the factory fill. My '04 has 231,000 miles on it.
Never add anything to my fuel either,. Usually use regular fuel although I was running Sinclair premium at Bonneville. Many old threads about which fuel to use. I was branded a cheapskate for buying an A8 but not using premium. That was when the difference was 20¢/gallon for regular vs. premium. Now the difference is 30¢/gallon. Still running regular even though I paid $1.93 yesterday in Toledo. Photo shows why E-85 sales have recently ground to a halt.
Check out my Bonneville album in my profile from this past Summer when the car had only 216,000 miles. Runs pretty good for never using any additives.
I bet you're getting misfires, they're just under the threshold to trip CEL. My fiancee accidentally put 87 into our A4 and it tripped right away (multiple misfires).
E85 has always been an asinine premise for 90% of people.
I agree with the E-85 statement; It represented a value when regular was $4 and E-85 was $3 though.
Entertaining a suggestion of running oil cleaner through the car through wide range of RPMs/Gears to hypothetically get into the clogged drain in that pump and then change oil immediately. I may try this as it seems pretty relevant to owners changing oil brands/formulas. Atleast its worth a shot before replacing timing chain guides/pump only to still hear it like other owners have reported.
I've also personally used fuel treatment by Chevron/Techron in a couple vehicles and I feel a slight improvement in the smoothness in acceleration through the range of RPMS and maybe less vibration at idle. Used sea foam once on my first 240sx and it didn't hurt a thing either; think I was trying to solve a timing chain tick but it didn't work.
None except Techron, w/ Tier 1 gas
Techron maybe every 3-5K miles. When I did a head rebuild on the 2000 A6 4.2, I found minor deposits on valves at 100K+. When I had intake off of W12 to do spark plugs recently (around 105K--easiest + cheapest way to get at them is pull the whole magnesium intake at its riser base), intake valves were pristine.
No additives in tranny ever; used to use MOS2 in manual gearboxes and diffs but that was way back in the mid 80s and pre synthetics.
