What I Learned in the Snow Today
#11
I think quattro sucks. Well, maybe does not suck, but its not really good. My two right wheels did not have any traction(read were in the air) and left wheels would not move at all. Was pretty embarrassing to be pulled out from snow by couple rednecks driving a pickup truck. "Audi did not make it, he?" is not what you want to hear.
Since then I trust just my Grand Cherokee with quadra drive
Quattro is good only when all four wheels have traction. Its meant for performance driving, but its definitely not up for challenges.
Quattro, X-drive and 4-matic have also ESP (or similar) that should help in snow, but it's not magic. 50% of all those systems is a driver. So nose winch or this one.
<iframe width="420" height="315" src="//www.youtube.com/embed/mnOyScZhTbE" frameborder="0" allowfullscreen></iframe>
#12
Quattro is not all terrain transmission, but neither quadra is. Same thing with mechanical LSD of all kinds. Only real one is fully blocked all three differentials. Even that helps much more before the vehicle gets stacked.
#13
AudiWorld Wiseguy
The theory is that the spinning wheel is braked so transferring torque across to the other side. However if the other side has no traction also then no amount of diff locks would help, whatever their type. If you have insufficient traction on all 4 wheels then all you'll get is all 4 wheels spinning and you still going nowhere.
#14
Quattro, X-drive and 4-matic have also ESP (or similar) that should help in snow, but it's not magic. 50% of all those systems is a driver. So nose winch or this one.![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
So coming back to what I said, quattro (along with xdrive,4matic and others) is 99% good for regular road snow driving. What happened to me, was two wheels were on the road and two were in the ditch, not having any traction. Pretty rare occasion, but that was when quattro failed.
#15
#16
My '87 5000CS quattro had both inter-axle and rear differential locks. Boy, I miss that car. 286,000 miles before donating her to charity. She served me well. And it had a 5 speed manual transmission.
#17
Yeah, but Jeep has 4lo, ability to lock both front and rear axle together
Never had to use it though, but like having that option. Its a 2004 Overland, last year model they had solid axles, good for offroading, but not good for freeway driving.
As it has been pointed out, Audi's used to have a rear diff lock (WAY back in the day), which would help here. Many trucks use the Eaton G80 locking diff on the rear axle, which would help here. Hardcore off-roaders run various different brands of locking diffs, front and rear (and of course they have the transfer case locked front to rear).
The current version of Quattro works really well in 98% of on road driving, but it has its limits. The "electronic diff locking" whereby the ESP computer brakes the slipping wheel in an attempt to shift torque across the axle works reasonably well, as long as the difference in traction isn't 0% to 100% across the axle.
The most impressive AWD car that I have ever owned was a Subari WRX STi. Variable torque split from a base of 35/65 to 50/50 front to rear, with limited slip diffs in the rear AND the in the front.
The new Torsen III Quattro (40/60 base split) cars with the Sport Differential likely have an advantage here, as the Sport Diff has the mechanical ability to move torque across the rear axle without solely depending upon braking the slipping wheel. The front diff, however, is still open.
Remember, though- these are performance minded street cars. Not off-road trucks, and not rally cars. The STi was about as close as you could get to a street legal rally car, but still lacked the rear drive disconnect when you pull the e-brake (among a long list of things that "real" rally cars have- like a roll cage).
#18
One of the most advertised features of Quattro is Torsen mid differential, but it is actually quite useless as LSD here. When one axle has zero traction other one doesn't move at all. Just like any opened differential, except it requires extra expensive oil. No wonder that others doesn't use it. Including newest Audis.
Problem with mud/snow traction is that only gentle movements work and none LSD works than. It has to be active and programmed for those purposes, probably switchable (intelligence necessary in order to distinct parallel parking from stacked in snow), or just fully locked. ESP has to work much smoother in order to help here. Just rough braking wheels with no traction makes rest of them to loose it.
#19
This is why in a true performance car, you want a clutch and ramp type LSD (or possibly one of the new, gerotor based units like the BMW M diff). If a wheel lifts while in a corner, you still get the same degree of lockup that you would were it still on the ground. LSDs also lockup on deceleration, which is especially useful in stabilizing mid and rear engine cars on braking. This is why all the fast Porsches you see on the track run clutch type LSDs.
Off road, as mentioned above, it's all about locking diffs- center (transfer case), and front/ rear lockers. What is a bit interesting here, however, is that the real Hummer is actually an AWD truck.
