Sponsored by:
Sponsored by:
What oil brand do you use in your A8?
Old 10-13-2012, 07:15 AM
  #41
Matt@H2OTuning's Avatar
Originally Posted by bmwm750
As far as Rotella (especially the T6 variant) being "truck oil," that's actually a pretty good thing- especially if you want to run an extended drain interval. Unlike all the modern car oils, the diesel oils still have quite a bit of ZDDP in them (good for bearings, bad for cats), and, being designed to keep diesel soot in suspension, tend to deal quite well with extended drain intervals.
I have used Rotella T6 in every car that I have ever owned from my MK2 Jetta, My A6 2.7T, and even my Porsche 996. I will be using it in my A8L as well. One thing that I have always liked about it is that the slight lifter noise you get from cars is reduced.
Old 10-13-2012, 12:47 PM
  #42
bmwm750's Avatar
Glad I'm not the only one!
Old 10-13-2012, 01:03 PM
  #43
Brozee's Avatar
How's it been running in your A8? Using this oil would save me a ton with the w12 considering using around 13 qts of oil. vs the cost of mobil 1 even though its still not that expensive for high quality oil
Old 10-13-2012, 01:11 PM
  #44
mishar's Avatar
Rotella T6 is primarily designed for Diesel engines. That means it has additives to deal with sulfur acid, product of burning Diesel fuel (way less with recently adopted standard for NA). It is also API SM rated, so good for gas engines too. Even better if one is a truck driver and it comes really cheap.
I am using Red Line 0W-40, but I am positive that any modern oil will do.
Old 10-13-2012, 05:13 PM
  #45
Mike141's Avatar
I have been doing my own oil changes on the A8 since I've owned it, about 3yrs. Always used Castrol Edge 5w-40. Have to admit, an oil change in this car is a major pia! Glad there is a 7-8k increment!
Old 10-14-2012, 05:19 AM
  #46
Mister Bally's Avatar
I thought the interval is 10,000 miles.
Rotella, with limited choice of weights is usuallu cheap in 5 gallon pails at Costco and Sam's.
For a better selection; one need only to staop at a Pilot/Petro/Flying J truck stop and peruse the selection in the Trucker's store. Problem with Rotella is that although I did find either a 0W-40 or 5W-40 weight, it did not have either VW designator so I stayed away. I've been using Total lately instead of Valvoline and Volle.
Old 10-14-2012, 06:06 PM
  #47
A8 LOOONG's Avatar
Default AMSOIL?
I've read through all these posts about oil and I don't see AMSOIL mentioned. Am I the only one that uses it? They offer a 5W-40 Euro Blend that meets Audi's API standards and as a "Preferred Customer" it comes out to about $5.75/qt.
I don't miss changing oil on my old A8L. That was a PIA compared to the S8. After the belly pan is removed, there's one allen screw drain plug way at the front of the engine and the filter cap unscrews at the firewall. The filter cartridge is lifted straight out the top. Couldn't be easier. Drain, set a new cartridge in the filter chamber then fill'er up with 10.6 qts -- done!....it also helps to put the drain plug back in.
Old 10-14-2012, 06:17 PM
  #48
Brozee's Avatar
Lol well the reason I don't use it is because it is very very expensive! Without your preferred discount lol, mind sharing it with me? Happen to know where the filter is on a w12 by chance?
Old 10-14-2012, 06:29 PM
  #49
A8 LOOONG's Avatar
Ha ha, well at risk of pissing off the non-vendor police I can say that becoming an AMSOIL preferred customer takes all of 10 minutes + $20/yr. Sign some forms and voila' -- you too can be a preferred customer. I run their stuff in everything I own -- even the lawn mower. I've read quite a bit of their performance studies and they seem to have a superior friction protection product.
W12 oil filter location??? Got me....
Old 10-14-2012, 06:39 PM
  #50
Brozee's Avatar
Well great. Please pm me and point me to those forms or how to.
Quick Reply: What oil brand do you use in your A8?
