Wheel Alignment
I am not sure if my wheel alignment is good so I decided to check it myself. I have laser level/plum, so I've aligned it with the car and measured distance from the beam to the front and rear quadrant of each wheel. To align laser I aimed it so that distance between the beam and wheel center at the front is 7 mm less than at the rear (front track is 14 mm greater than the rear).
Results: Front left and right: Toe in 1 mm (1.1°) Rear left and right: Toe in 2 mm (2.2°).
Now I have to search for alignment data.
dtompsett
12-02-2007 01:53 PM
$teady$upreme
02-20-2002 07:14 AM
