Wheel sensor fault!
My 2006 A8 had the anti-lock light, stability control light and electric brake warning symbol all come on. Vag Com says right front wheel sensor is not responding. I checked wheel sensor and used di-electric on contacts. Anyone know how to check for signal at sensor or should I just replace the sensor? I need to see where this line from hub plugs in somewhere on chassis? Any ideas or suggestions.
I saw on line (not OEM) ABS wheel spin replacement sensor.( amazon $11.00)
Auto Front Right ABS Wheel Speed Sensor Fits Audi 4E0927804D
by Amico
Be the first to review this item
Price: $10.93 & FREE SHIPPING
Listing says Dealers clean sensor when a problem instead of replacing??? Any one have had same issue?
by Amico
by Amico
by Amico
Yes, iron filings from the.toothed wheel can get stuck to the magnet on the face of the sensor and trigger erratic wheel speed faults. Wipe the face clean.
These filings will not affect the test above.
Also, if you have an $11.00 car, buy an $11.00 sensor. Otherwise, make sure it is a Bosch sensor. This is a safety-related part and system. Buy Chinese junk air filters and trunk liners but not an ABS sensor please.
No wire kits available for the car (the car's wire looms are made to order for specific vehicle), and not for the sensor too. You have to replace just the broken part of the cable. Please do the work correctly, i've seen too many "isolation tape fixes".
You get the same wire gauge and color, and some heat shrink tube, an heat-airgun, and soldering iron with solder. See to that the fix is watertight.
faciest
10
10-03-2023 12:49 PM
diamond8990
08-08-2002 07:59 AM
