Where is this thing? Parking Aid Warning Chime (H15) Open or Short to Ground
Code:
1 Fault Found: 01543 - Parking Aid Warning Chime (H15) 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 4 Mileage: 160588 km Time Indication: 0 Date: 2014.01.08 Time: 09:24:40
From what I gather, this is a problem with the speaker and not the sensor?
Any help is appreciated!
I ordered a replacement speaker, but haven't replaced it yet. It's cheap ($22 from Genuine Audi Parts).
I ripped out the carpet, couldn't find anything so I put it back. Then Mishar was kind enough to post the diagrams above. I plan on making another attempt this week when I get time.
I got the long beep too, but mine is a parking sensor in the rear bumper...Been going on for about 2 months now. I assume I have to replace that sensor. Does anyone know if I just disconnect the sensor unit I get the replacement that the system would function normally? Thanks
Thanks again, Mishar.
Posting pictures in case it might help someone else.
- Remove the top trunk liner. It's a few plastic rivets and 4 phillips head screws that hold up the grocery bag hangers
- Towards the back of the trunk (bumper side) you'll see an oval plastic piece with a small access hole to the side. Just to the right (passeger side) of that you'll see two white rivets and two black rivets.
- The black rivets are the speaker that you need to replace. Pop those out and you can slide the speaker out through the access hole.
