WTB: Rotors, Pads and lines 2008 W12
60k miles on the ol gal. Replace pads light has the Mrs scared and demanding this be addressed immediately. Hilarious. Can't stomach going to the stealership. On other forums I belong too a post like this will initiate vendor contact which is what I am hoping occurs. Houston Texas area....
Gracias in advance yal
I would suggest OE rotors, which are price competitive with most better rotors if you get from an online discount dealer like audiusaparts. Watch on shipping for rotors in general, which can get expensive with the weights--front W12 rotors weigh 40 pounds, EACH. For pads, either OE or known reputable brand. I use EBC reds for what its worth, but also have used OE for replacement. Similar, and similarly priced, other than EBC has somewhat less dust. Check rotor wear too--if never changed before you may be getting close on fronts, but may notoo--W12/S8's are specific so the slam bang vendor with the generic 4.2 "today's great offer" might not work out so well...
Check rotor wear too--if never changed before you may be getting close on fronts, but may not need rears quite so fast. FWIW, if rotors previously done--like by an earlier original owner with a thick wallet who was talked into them erroneously by a dealer--you are pretty much just burning extra dollars like a prior owner did. In plain English, my experience specific to W12 is the rotors can go about 75-90K miles of mixed driving until they hit the wear limits (3mm front, 2 rear for W12/S8 IIRC). If you don't know prior history specific to rotors, you really should get a wear measurement. Its worth something like $600 to you for quality rotors (discounted), plus shortens labor time a fair amount if a pad only change.
As always your input/response is much appreciated. Will measure the rotors before going too far, also will check the sensors, etc. Replaced oem on the GTR last week with J-hooks and endless mx72 pads. What a difference.
If, after the measure I need to replace... will do the lines as well. 8 years of wear and tear might as well since we intend to keep this car. Like the slotted appearance, EBC has the black face (I know it wears off) that if it doesn't cost anything extra will be slick for pictures.
No vag-com
Will have installed
No vag-com
![Frown](https://www.audiworld.com/forums/images/smilies/frown.gif)
No vag-com
Will have installed
No vag-com
If you are getting into lines and such, eventually replace the rubber bushings the calipers slide on in front. But that's more like my 110K plus miles , not your 50K plus. If your pad retainer clips are rusted in front--that silver face you see on outside of caliper--you can get inexpensive jobber ones from Rock Auto and similar sites. They are one of very few second rate (non) finish issues on D3's. They also sell other obscure jobber stuff like the stainless clips you fit into the caliper bracket the pads slide on. Way cheaper than (overpriced) Audi equivalent parts. But again, more for higher mileage and only when you do more thorough work like rotors, hoses etc. Also on hoses, if you do rears, realize there are two hoses on each side--one toward the caliper and another from body to lower arm.
I have a set of W12 rotors for sale. Brand new.
Also have what you really want - a BBK - see my signature....
I spend time in Houston so could get the rotors to you pretty easily without shipping (which is a killer for any rotors, btu esp for these). As MP states above the W12 rotors do weight 40 lbs each, versus 30 lbs for stock 4.2 rotors.
Send me a PM if interested.
No vag-com
Will have installed
No vag-com
Excellent work, fast, and honest. Do my Beemer, Sequoia, and XJR too. Plus unlike some other indies in Houston you can source your own parts if you prefer.
N'Syncro
33
02-16-2020 03:12 PM
Curtisjh
09-04-2015 04:06 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
