WTF!?! My D3 barely started after sitting a day and with a brand new battery
Well I just went out and started the D3 in the garage and I had the radio and stuff playing for a few minutes and had the system will shut down if the engine is not started in 3 minutes. I try to start it and nothing and the lights were dim and I kept trying like 3 times and after the fourth time it started cranking real slow and it started. I bought the battery from advance auto with a 3 yr replacement warranty for $113 with tax and exchange since the dealer tested my old battery to be bad when it failed a load test. There's no way I'm going to pay $207 plus tax for a dealer battery which only has 1 yr 12,000 mile free replacement. I know I didn't leave anything on to partially drain it.
What do you think could the problem be?? I hooked everything up on the battery like it should like factory. Does something else need to be programmed for it not to do that like VCDS?? Ok thank you.
I would load test the new battery. It could be just a bad battery. I would eliminate the battery first.
It could also be a starter going bad. You said you tried a few times and nothing happened but then it cranked slowly and started.
Test the battery - measure the voltage - charge it to
see if it holds - It could be sitting for a long time and it's a bad battery. Does your car have any after market devices - Music player and such? Original Audi devices will turn off if not used, but the after market devices may not. Hope it's something simple.
Cheers,
Louis
Cheers,
Louis
I just got the battery put in like 3 days ago and the car is bone stock with no add ons. The starter is fine because when I tried to crank the lights were dim and finally it kicked in and started. It is a 900CCA battery and a 1000CA I started up an hr or so ago and let it idle for almost an hour. I'm wondering if I left out a step by not reprogramming the battery possibly?? Maybe it doesn't have enough reserve capacity. I'm thinking I haven't driven it enough on the new battery and only put like 3-5 miles on it since then. The battery has been manufactured on 3/14.
Yes, 1. code the battery and 2. check a connection
1. Yes, you should code the battery to the car. You need VAG COM. If it isn't an Audi battery, the std. technique is to just increase the prior stored battery serial number by 1. Search archives as needed. The car will probably eventually figure it out if you don't code it, but without doing so your car charging system will behave as it would with your old battery. Thus, it may think your battery can't hold much juice still.
2. Make sure you hooked up the little wire that is attached to the positive lead right at the battery area. If you didn't, or the wire is (or got) broken, the charging system will act up.
I quit buying store brand batteries from Sam's, Walmart, Autozone, or Advanced. Several failed real early.
But either you need to drive the car and fully charge it up, or this is why you put a new battery in three days ago.
Just get a good battery charger and charge it
I got this <a href="http://www.amazon.com/dp/B000BQSIWK/ref=as_sl_pd_tf_lc?tag=dognmonkey-20&camp=213381&creative=390973&linkCode=as4&creati veASIN=B000BQSIWK&adid=0C7NC0AKW6YA7G0D7F4F&&ref-refURL=http%3A%2F%2Fwww.dognmonkey.com%2Faudi%2Fup date-audi-mmi-3360-to-4610.html">battery charger</a> which can tell what % of the battery level. When the battery seems low, I just charge it with 2A for a few hours, when it shows 99%, I'd disconnect it.
My old original battery would last the whole week without driving and still starts without any problems.
Use DVM to check voltage of the battery
It should be a problem with a very simple solution.
Cheers,
Louis
Cheers,
Louis
Well I figured it out. I changed the serial number on the last digit by increasing it by 1. We will see what happens from here on out and my battery level meter should be a little more accurate with the change. I have always used advance auto batteries and I've never had problems with it except I had this mercury villager van for 3 yrs and for the last year I barely drove it and there were times when I had my tools in there and leave my hatch open and the lights stay on and the battery drains quicker because I barely drove it which is my own fault. I finally decided one day to warranty the battery out and they said it needs charged and I tried that and I knew the guys there and they hooked me up with a new battery free of charge. Other than that I've never had problems with them, I know those everstart batteries from Wal-Mart are garbage and usually last right at or right after the free replacement warranty.
